will a rear 4 lug hub fit a 5 lug jdm itr spindle?
Mr. Badwrench
before you go wtf, it is like this.
eg with a 5 lug. too much power for 15"s.
swapped fronts out to 4 lug, needed bearings and hubs for the dss level 5.9 axles.
the rears i got werent in that great shape. i want to put the 4 lug hub and re drill the rotor for 4 lug. it is the easiest thing to do time wise. i have someone to buy the skinnies in 5 lug and want to get the wheels i have on the front to match.
cliffs. will a 4 lug gsr rear hub fir a 5 lug jdm itr rear spindle?
Cool Cool Island Breezes. BOY-EE
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boostedcivicsir »</TD></TR><TR><TD CLASS="quote">before you go wtf, it is like this.
cliffs. will a 4 lug gsr rear hub fir a 5 lug jdm itr rear spindle?</TD></TR></TABLE>
Yes, it should. The hub bolt patterns are the same to the spindle. Im 99.9% sure
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by got wide »</TD></TR><TR><TD CLASS="quote">ok my question is kinda the reverse. what do i have to do to convert my 94 ls hubs to itr 5 lugs</TD></TR></TABLE>
You need 5 lug hubs and wheel bearings. Or the entire spindle set and trailing arm from an ITR (usdm if you want to keep your existing axles the way they are).
If you get JDM itr Spindles, you will need the outer axle from either a JDM itr, bb4-bb6 prelude, or 94-97 accord.
CTR spindles are a bolt on affair, axles and all but you'll need an alignment as the attachment points for the tie rods are different lengths. So you will have horrible toe in problems if you dont get an alignment with CTR spindles.
