Honda Minivans, Crossovers, and Trucks Honda Odyssey / Ridgeline / Pilot / HR-V
Acura MDX / RDX
New owner, usual little faults
Old Mar 26, 2007 | 06:02 AM
Andy_P2002's Avatar
Default New owner, usual little faults
Hi all.
I'm a new owner of a '99 CR-V and guess what? The clock only works when I hit it and the driver's door doesn't lock/unlock with the remote.
Looking on the forums, these seem to be pretty standard problems so...
1. I know the clock is probably down to dodgy connectors or soldering on the PCB and I'm very confident I can sort that... what I DO know is that I'll snap all the clips off trying to work out how to get the air vent panel out of the dash.
Could anyone who's done it, give specific details? (I guess it needs a flat spatula or two slid down the gap, but do I 'push', 'slide left and right', 'twist' or what?
2. Where do I start, tracking down the door lock problem. If it is most likely to need a new actuator, I won't even start pulling it apart (I've had enough trouble inside doors before!), but if it is likely to be just a lubrication job or plug fallen out, I'll give it a go.
Any help would be much appreciated, Thanks.
YoShina
Aug 27, 2013 10:25 PM
pjbertrand01821
Honda CR-V & Element
10
Aug 10, 2013 03:26 AM
jxhxb
Jan 31, 2008 10:14 PM
cdagza
Honda Civic (2001 - 2005)
Mar 30, 2006 10:14 PM
Adelphoi237
16
Feb 25, 2005 12:43 PM
