K20A2 ?s
Old Mar 25, 2007 | 10:02 PM
johnclaunch's Avatar
Default K20A2 ?s
I am swapping a K20A2 into my 05 EP3. Some research then questions.
The K20A2 produces 197hp@7000rpm, 142ft/lb of torque@6000rpm. Redline is 8000.
This is the same spec as the EDM K20A Civic Type R.
Since all EP3s were made in the same Swindon, England plant, the Type R was shipped to Japan where Honda made some changes to the JDM model to make it perform:
215hp@8000rpm, 206ft/lb of torque@7000rpm. Redline is 8000.
The changes consisted of different camshafts and different ECU settings.
Also, the EDM Type R did not come with LSD, as did the JDM models. Both had a 6 speed, however, and the EDM did not come with Recaro seats.
The A2 I am getting has the 6 speed Type S tranny with factory LSD attached, so I will not have to worry about adding it later.
Anyone figured out the fix for the grinding issue with 3rd gear in high rpms?
My main question:
If I swap DC5R camshafts into the A2 with K-Pro tuning, I should be getting better than Type R performance stock for stock, correct? I am also running header to tip exhaust with no cat, and CAI.
Any discrepancies with any info above, let me know. Thanks.
Old Mar 26, 2007 | 12:39 AM
Aco512's Avatar
sorry, this doesn't answer your question
last i check type-s' don't come with lsd from the factory
are you referring to the dc5 type-r tranny or the 06-07 si tranny?
Old Mar 26, 2007 | 06:26 PM
bentrootz's Avatar
how much is it to swap a k-20 engine type r into my 2002 acura rsx type s?
Old Mar 26, 2007 | 07:03 PM
WhiteOnRice's Avatar
Hah, not worth swapping a type s to type r. Nevermind, do it and I'll buy your k20a2.
Old Mar 26, 2007 | 07:40 PM
motiondc5's Avatar
Default Re: (fizix_skate)
Just get cams from a z1, they are prb's just like the k20a, except cheaper because they were also made here in the US. Both have same lift duration.
Old Mar 26, 2007 | 08:58 PM
Good luck finding z1 cams
Old Mar 27, 2007 | 03:50 PM
Aco512's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fizix_skate &raquo;</TD></TR><TR><TD CLASS="quote">Hah, not worth swapping a type s to type r. Nevermind, do it and I'll buy your k20a2.</TD></TR></TABLE>yeah that
only do it that if your motor is blown
Old Mar 28, 2007 | 10:39 AM
SiR99's Avatar
Default Re: K20A2 ?s (johnclaunch)
since when did the Type R k20 put down 206 lbs of torque? I thought it was something like 160
Old Mar 28, 2007 | 12:26 PM
BarracksSi's Avatar
Default Re: K20A2 ?s (SiR99)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SiR99 &raquo;</TD></TR><TR><TD CLASS="quote">since when did the Type R k20 put down 206 lbs of torque? I thought it was something like 160</TD></TR></TABLE>
Even 160 sounds high. One thing it's got going for it is that sky-high redline, which helps raise the horsepower figure quite a bit. My EP's 131 ft-lbs would crank out beyond 180 whp if it could rev to 8K.
Andrey
Honda Civic (2006 - 2015)
14
Sep 19, 2007 03:35 PM
OrangeP
Jun 7, 2006 05:33 PM
devilution
14
Apr 24, 2006 04:16 PM
hawjboi
Oct 2, 2005 06:42 AM
KF_S2000
Dec 1, 2001 09:45 PM
