clutch type LSD owners: what GL5 gear oil and friction modifier do you use?
Old May 24, 2002 | 05:25 PM
Michael Delaney's Avatar
Default clutch type LSD owners: what GL5 gear oil and friction modifier do you use?
I have a 2 way Kaaz LSD clutch type. The kaaz 90 weight GL5 gear oil is wicked expensive. I've switched to using Redline 75W90 GL5 gear oil but was wondering how much Redline friction modifier do you guys add to a full change in gear oil every 40-60k miles? I've heard anything from a capful to 1 part in 4. I haven't tried the friction modifier yet and it seems my LSD isn't grabbing as much.
thanks for your input.
PS some people use Ford or Chevy gear oil friction modifier as well.....
Old May 24, 2002 | 05:28 PM
ARunto's Avatar
Default Re: clutch type LSD owners: what GL5 gear oil and friction modifier do you use? (Michael Delaney)
I use castrol 80w90. I don't use any friction modifier.
-Alan
Old May 24, 2002 | 06:14 PM
RagingAngel's Avatar
Default Re: clutch type LSD owners: what GL5 gear oil and friction modifier do you use? (ARunto)
I just use Redline MTL and a bottle of Ford Fric....
No problems...
Old May 24, 2002 | 07:40 PM
Default Re: clutch type LSD owners: what GL5 gear oil and friction modifier do you use? (RagingAngel)
Rage,
you use a whole bottle with every change of gear oil?
Old May 25, 2002 | 11:41 AM
I use a full bottle of the frict mod. and then just pump MTL until it overflows and stops dripping.
That stuff smells like rotting grapefruit!! BleeeAHHhhhhhGhhhh!
rocketfuelcerx
Dec 17, 2006 08:22 PM
chrisb
Jun 12, 2004 10:45 AM
ToneyTigre
Dec 13, 2001 09:03 AM
ToneyTigre
Dec 10, 2001 06:06 PM
DC2R
Aug 14, 2001 04:03 PM
