crx brake help!!
Old Mar 25, 2007 | 08:44 PM
redwards's Avatar
Default crx brake help!!
ok well yesterday for some reason i was pumping my brakes and ive noticed that my rear right rear brake is leaking fluid...im a nooooooob a brakes so wtf do i do is it the piston leaking cause its spraying everywhere when i opened it up....and also what do i need to fix this...should i just buy a new rear drum?? im jsut a little confused because im not sure if the rear drums from the junkyards come with all the things i need. someone please help clarify this confusion ive gotten myself into.and if it helps its a 88 si
Thanks,
Ryan
Old Mar 26, 2007 | 06:34 AM
CRX Toad's Avatar
Default Re: crx brake help!! (redwards)
You just need to get a wheel cylinder from parts store. They are straight forward and easy. However you will need to take your drum apart to get to it. I just rebuild the drums on my car with new everything both side for about $120.
Old Mar 26, 2007 | 07:20 AM
89efDUSTY's Avatar
Default Re: crx brake help!! (CRX Toad)
or you can upgrade to DA brakes for around the same price... thats why i upgraded
Old Mar 26, 2007 | 01:22 PM
redwards's Avatar
Default Re: crx brake help!! (89efDUSTY)
What do i need for the da conversion?? is there a write up anywhere on it??
thanks,
Ryan
Agguhnitus
Suspension & Brakes
Feb 15, 2012 03:07 PM
em Dot
Sep 26, 2005 06:10 PM
johng
11
Oct 8, 2003 06:17 AM
Lei Siew Long
Jun 20, 2002 05:38 AM
