Questions about lsvtec engines
I have a 91 honda civic hatchback with a b18a1 in it. I just installed a new bottom end due to some stripped out motor mount bolt holes going into block. The bottom end that came out of it i was thinking about building it into a lsvtec. The only thing is i have a friend who owns a 2000 civic si and he has a build lsvtec in it and he ahs had nothing but problems with it. He told me not to do it because i will have problems with leaking oil and few others. also he said i shouldn't do it because if a lsvtec was meant to be in a honda they wuld have came form the factory with them. I need some help in figuring out what is best to do from someone who has experienced it. So if u can help me or give me andy advice it would be greatly appreciated.
LS/VTEC no issues here. We raced one for two years and now that motor is in a street car. As long as it is built correctly you'll have no problems. There are horror stories about everything.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CRX Toad »</TD></TR><TR><TD CLASS="quote">As long as it is built correctly you'll have no problems. There are horror stories about everything. </TD></TR></TABLE>
+1
Let me guess that your friend built the motor himself?
He probably didn't properly check clearances, didn't run the whole system right and screwed something up. Properly built an LS/VTEC can be more reliable than an OEM Honda engine from a Honda himself.
9 times out of 10 they aren't properly assembled. Unless you have extensive experience in motor building, which I would doubt since you need to ask this question, I wouldn't try it. I know I couldn't properly build an LS/VTEC engine, but that doesn't mean that you couldn't.
Lots of reading would help.
+1
Novz
Honda Civic (2006 - 2015)
14
Feb 14, 2011 08:51 AM
