QUESTION ABOUT 2000 ITR PARTS!!!
Old Mar 25, 2007 | 07:50 PM
itr590's Avatar
Default QUESTION ABOUT 2000 ITR PARTS!!!
I have a 2000 ITR (USDM #590), I am putting a JDM 96 type r motor into it. I bought a header for a 92-01 gsr/type r. Will this fit? And I plan on getting a high flow cat to match the header's 2.5 outlet. The question is, will the header fit and when I buy the cat, what can I do to make sure it's outlet matches up to the stock ITR exhaust? All these fitment problems are driving me NUTS!! Whats my best bet?
Old Mar 25, 2007 | 08:10 PM
teg97's Avatar
Default Re: QUESTION ABOUT 2000 ITR PARTS!!! (itr590)
the header should fit, I would do a search on here to see. I used to have a type r exhaust setup on my old LS and it fit. good luck
Old Mar 25, 2007 | 09:09 PM
itr590's Avatar
anyone else? bump
Old Mar 25, 2007 | 10:23 PM
tartje's Avatar
some of the vets will probably not want me to give you the info without searching, but essentially, yes, it will fit
AFAIK the only fitment issues you can get swapping amongst B-series is trying to put a manifold on a B18 designed for a B16, as its shorter.
its a common mod over here for people with 1.8 VTi Civics (same engine as your GS-R), to use the 4-2 section from a UKDM Type-R as a cheap upgrade
HTH
but in future, SEARCH before you make a new thread, chances are this has been answered 10x before
dynamo
Jul 17, 2005 08:54 AM
RuKKus
Mar 29, 2003 08:32 PM
RICHJ
Feb 28, 2002 10:33 AM
AznInvasion
Jan 28, 2002 07:34 PM
OK
Sep 29, 2001 01:55 PM
