Can 215/45 tires fit on a 89 civic?
Old Mar 25, 2007 | 07:11 PM
slidingninja's Avatar
Default Can 215/45 tires fit on a 89 civic?
Old Mar 25, 2007 | 07:27 PM
EF_LSVtec's Avatar
Default Re: Can 215/45 tires fit on a 89 civic? (slidingninja)
13, 14, 15, 16, 17 inch?
Old Mar 25, 2007 | 08:00 PM
Hazen85's Avatar
what size of rims r u trying to put before u can pick the size of tire
Old Mar 27, 2007 | 02:27 PM
Default Re: Can 215/45 tires fit on a 89 civic? (Hazen85)
17,s
Old Mar 27, 2007 | 02:59 PM
garageEF's Avatar
how low is your car? i had 205/50r/15's and they rubbed a **** load.
Old Mar 27, 2007 | 04:15 PM
Default Re: Can 215/45 tires fit on a 89 civic? (garageEF)
1.5 dropped
Old Mar 27, 2007 | 04:21 PM
fireant's Avatar
It really depends on the offset of the wheels and the amount of camber you'll have as well as the diameter and width of the tire and the amount of lowering. In the case of 17's the answer is "More than likely, YES".
Have you seen an EF with 17's before? They look too big to most people.
Old Mar 27, 2007 | 04:29 PM
CRX Toad's Avatar
Default Re: Can 215/45 tires fit on a 89 civic? (fireant)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fireant &raquo;</TD></TR><TR><TD CLASS="quote">It really depends on the offset of the wheels and the amount of camber you'll have as well as the diameter and width of the tire and the amount of lowering. In the case of 17's the answer is "More than likely, YES".
Have you seen an EF with 17's before? They look too big to most people.</TD></TR></TABLE>
Dude that is the rage man. I am going to roll 24's on mine this weekend at VIR.
Old Mar 27, 2007 | 06:54 PM
EF_LSVtec's Avatar
The best way to find out is to measure the overall diameter of your current wheel/tire combo then check http://www.tirerack.com and if you look at the specs of whatever tire you wish to buy, it will tell you the diameter and width of that tire...From there +/- you can tell how much more you'll gain by going 17 inch rims. I hope this helps.
Drewsgotshoes
Feb 18, 2017 08:30 PM
1sick740
Mar 16, 2013 11:20 PM
JSPECSIR
Sep 23, 2008 02:17 PM
JaSoNe
Oct 25, 2006 11:03 AM
reXem
13
Jun 11, 2002 08:53 PM
