Draining Fluidyne Radiator ???
Its setup different and has no valve its like a wingnut and if u turn it to loosen it, it breaks loose and doesnt do anything. I am very confused. ANyone know how to drain it ?
My Fluidyne has a drain valve. The Fluidyne in my friend's track car has a drain valve. I'm sure yours does too.
The wingnut sometimes comes loose from the drain valve. You can probably loosen the fitting with a wrench to drain the rad.
Loosen that wingnut and take the rad cap off so that air can enter the radiator to replace the coolant coming out.
That wingnut-looking thing is a type of drain/release valve. It doesn't come off, it just lets coolant flow from the center of it.
Yes I know there is a drain plug but when i went to loosen the wingnut and it just came loose and is spinning. Im just wondering if i did something wrong and how i can drain it now ?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hawkze_2.3 »</TD></TR><TR><TD CLASS="quote">Loosen that wingnut and take the rad cap off so that air can enter the radiator to replace the coolant coming out.
That wingnut-looking thing is a type of drain/release valve. It doesn't come off, it just lets coolant flow from the center of it.</TD></TR></TABLE>
Did you read that buddy??? Pretty clear that the wingnut IS the drain valve, spin the nut loose and take off the radiator cap.
xlusiveracer
30
Feb 10, 2017 11:49 AM
