h-brace
an h-brace acts to help tie together parts of your suspension, so as you add the lower tie bars, front and rear upper struts, coilovers,etc.., it will become a road-racing/drifting car... Like a lower-tie bar, it will lower your ground clearance.
To answer your question, pretty much (below not my writing):
As you drive your car undergoes stress as your whole chassis will twist and absorb a lot of energy created by the force of inertia and gravity. Over the years, its been proven that a performance vehicle must reinforce the chassis and make a more rigid frame by connecting points in your vehicle that are crucial to the behavior of your vehicle.
By connecting points in your chassis and reinforcing the frame you are able to channel that energy that is being absorbed by the chassis flex back into your suspension components. This allows your suspension components such as your springs, shocks, and sway-bars to do their job more effectively with more stability.
An H-Brace connects the underside of your chassis and frame by connecting 4 crucial points underneath your chassis that undergo the most stress during cornering. Professional installation is HIGHLY recommended due to the familiarity of the connections between the chassis and subframes.
Modified by ke98248 at 7:35 PM 3/25/2007
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blackhope121 »</TD></TR><TR><TD CLASS="quote">yeah it reinforces the lower frame.. I strongly suggest you dont get one if you daily drive..
I just bent mine and now my alignment is all fucked up</TD></TR></TABLE>
You must be riding very low. I daily my hatch with it and no problem. It may be scratch and dent but it didn't hurt the performance at.
