Why oh why won't my D16 die!!!
I just thought I should let the world know a bone stock D16 with extremly high mileage can be beaten and pushed to the limits without breaking if properly tuned. I recently bought a used 93 Ej2 civic with 180k miles and I decided to build a custom turbo set up. I've been driving the car for 4 months now on 20psi of boost
and the thing just won't die!
T3t4 50 trim, All custom top mount header, 3in. DP, 2.5 inch charge pipes, small intercooler
turbonetics WG, RFL BOV, engine management is SDS EIC-4, with a BTM, talon oem FP, 8 oem civic injectors.
We were just out boosting again and we thought we'd bring along the camera. check ou these pics and vids.
http://s9.photobucket.com/albu...0.flv
http://s9.photobucket.com/albu...8.flv
http://s9.photobucket.com/albu...7.flv
http://s9.photobucket.com/albu...6.flv
Modified by haveaNOSday at 9:46 AM 3/26/2007
Links don't work for me, goes to the photobucket homepage?
That's impressive though, how much power is it making and on what fuel? Could you post the dyno chart? What kind of filter is that on the turbo?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SovXietday »</TD></TR><TR><TD CLASS="quote">****, if you don't want it, I'll take it... and the topmount too while you're at it.
It's yours if the price is right.
</TD></TR></TABLE>It's yours if the price is right.
Any more info on the setup, like ems or general amount of timing retard? 20psi on pump gas is good just by itself, the fact that its on a stock D with a t3/t04... thats amazing.
everyone that tries to blow their motor, cant blow it and everyone that doesnt want to blow their motor, blows it! BTW: can u get a 1-4th gear pull video?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EJ1 wilcox »</TD></TR><TR><TD CLASS="quote">You are using 8 OE injectors??
Any more pics/info on your fuel setup?</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HiProfile »</TD></TR><TR><TD CLASS="quote">Any more info on the setup, like ems or general amount of timing retard? 20psi on pump gas is good just by itself, the fact that its on a stock D with a t3/t04... thats amazing. </TD></TR></TABLE>
sorry no pics yet I'll try to post some soon. There is 8 oem D series injectors, 4 in stock location with the other 4 installed in a costom plate between IM and head. BTW thats all with stock lines, fuel rails and FPR. Manegment is SDS extra inj. controller 4, with a msd BTM @ .75 degree retard per pound.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2redstars »</TD></TR><TR><TD CLASS="quote">which map sensor are you using?</TD></TR></TABLE>
Stock honda map with a missing link idles perfect at 900rpm, and the EIC-4 has an internal map good up to 22 psi we've gone as much as 21 psi no probs.
