-6AN Water Cooled Turbo Stainless Steel Coolant Lines. Great for GT30/35R and more!!
Old Mar 25, 2007 | 05:41 PM
AMR Engineering's Avatar
Default -6AN Water Cooled Turbo Stainless Steel Coolant Lines. Great for GT30/35R and more!!
I have 4 total that I am selling. These are 18" long and come with -6AN ends. This is what I use for my coolant lines on my GT35R. These are awesome and will provide you with a very clean install. I only needed 2, but I got a few extra.
These are 30.00 bux a piece and shipping is about 8.00 Bux. If you do the math this is a bargain. The 45 degree AN fittings alone cost about 19.00 bux each, plus the cost of the -6 stainless steel line. Then on top of that you have to put it together.
If your interested please PM me. The prices are FIRM!
If you need the rest of the fittings to complete your coolant line setup I recommend my friend Stan at http://www.fast-turbo.com/ He will known exactly what fittings to sell you.
Old Mar 25, 2007 | 06:05 PM
Tzarinque's Avatar
Default Re: -6AN Water Cooled Turbo Stainless Steel Coolant Lines. Great for GT30/35R and more!! (AMR Engine
are coolant lines compltely necessary though?
Old Mar 25, 2007 | 07:32 PM
b20turbojason's Avatar
precision will not warrenty any ball bearing turbo if you dont use them. we had one go bad on us the min we put it on the car (when it was on the dyno). we werent using the coolant lines they didnt warrenty it. so know we always install them on ball bearing turbos. got to have that warrenty cause it can happen
Old Mar 25, 2007 | 09:14 PM
ProjectBoosted's Avatar
can someone post a pic of a turbo installed with the coolant lines on it? I am interested in the lines but where do you hook them up? I have a precision gt35r ballbearing turbo brand new that i am going to be using on a topmount in a DC2 integra with a halfsize rad.
Old Mar 26, 2007 | 12:03 AM
Depends on the car. I have a aftermarket radiator so I have a bung welded on the bottom of my radiator for my feed. The drain goes to a fitting where my old fitting for getting air bubbles out of the cooling system was at. I took that fitting out and tapped it so I can use it as a drain.
Old Mar 26, 2007 | 09:49 AM
Tzarinque's Avatar
so would you say that if you have a water/oil cooled BB turbo that doesn't have a warranty offered, would you still get the water lines.
Old Mar 26, 2007 | 10:25 AM
My GT35R is not even from Precision, but I choose to use it at all times. It's there for a reason.
Old Mar 27, 2007 | 12:39 AM
Old Apr 2, 2007 | 06:37 PM
BodyKits NW
Northwest (Sales)
Jun 19, 2007 03:13 PM
BodyKits NW
Mar 20, 2007 02:42 PM
KevronsEG
Jan 28, 2007 06:50 AM
BodyKits NW
Nov 2, 2006 06:49 PM
RTW DC2R
Jun 3, 2006 07:20 PM
