Balljoint Removal
Old Mar 25, 2007 | 05:40 PM
kornerk12's Avatar
Default Balljoint Removal
In order to remove the upper,lower and tie rod balljoint what size pitman arm puller do you need to use ? Also in order to unload the joint what should I jack up the frame or LCA ? And after removal is alignment required ?
Old Mar 25, 2007 | 05:56 PM
Montx's Avatar
Default Re: Balljoint Removal (kornerk12)
I dont know about the pitman arm puller, but I do know as long as the replacement equipment is of the exact length alignment isn't necessary.
Old Mar 26, 2007 | 07:08 AM
kornerk12's Avatar
Default Re: Balljoint Removal (Montx)
bump
Old Mar 26, 2007 | 05:23 PM
kornerk12's Avatar
bump
Old Mar 26, 2007 | 05:25 PM
hu's Avatar
hu
You need 28mm and 32mm
Old Mar 26, 2007 | 05:28 PM
kornerk12's Avatar
Default Re: Balljoint Removal (hu)
the one i already have has a 27mm opening ??? is that too small ? Do I need another one 32mm regardless ?
Old Mar 26, 2007 | 08:45 PM
hu's Avatar
hu
Helms says you will need 28 and 32mm. Go to a local auto parts store and rent a ball joint removal kit.
Old Mar 27, 2007 | 06:18 PM
kornerk12's Avatar
so with a 27mm and 32mm pitman arm puller i should be able to get the tie rod, upper and lower control arm balljoints correct ?
NMJimCRV
Honda CR-V & Element
Oct 13, 2014 08:30 PM
BCGARAGE_ED7
13
Feb 11, 2013 01:47 AM
MalcolmV8
Apr 5, 2011 09:01 AM
EFin' Kyle
Mar 31, 2009 05:08 PM
munoz86
Dec 4, 2008 03:59 AM
