91 civic suspension question
Old Mar 25, 2007 | 04:23 PM
Josh22999's Avatar
Default 91 civic suspension question
Hey everyone I have a project going on and would like your oppinion on a good suspension setup...I did a b18 swap and I will be turboing it. I am just wondering what you guys think I should use for suspension probably a full coilover...let me know
thanks
Old Mar 25, 2007 | 07:55 PM
EF_LSVtec's Avatar
Default Re: 91 civic suspension question (Josh22999)
What application, Road, Drag or AutoX racing?
Old Mar 25, 2007 | 09:54 PM
nihad's Avatar
For a nice ride just get some gr2 from advance and get some coilovers so u can adjust you ride. You might wann change the front camber get revo2 from ebay and get some rear ones if you want.
Old Mar 26, 2007 | 07:14 AM
91efhondacivicsiNApowa's Avatar
Default Re: (nihad)
Koni yellows are pretty good i also hurd bilsteins are pretty nice my friend has um on his s2000 but ya i have koni yellows on my ls vtec swapped 91 si hatch and its a great ride.
Old Mar 26, 2007 | 07:17 AM
Ass$nyper's Avatar
Pirate General...YARRRR
Default Re: (91efhondacivicsiNApowa)
good work you too on the random part jocking when you have no idea what he will be doing
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EF_LSVtec &raquo;</TD></TR><TR><TD CLASS="quote">What application, Road, Drag or AutoX racing?</TD></TR></TABLE>
As always good call, and yes knowing what you will do with the car helps a ton.
Old Mar 26, 2007 | 12:52 PM
Josh22999's Avatar
Mostly for the road I will be at the track running it to.
Old Mar 26, 2007 | 07:27 PM
EF_LSVtec's Avatar
If you don't want to spend an arm and a leg for suspension, you can get a set of Koni yellows/Ground Control combo...Good thing about this set up is you can get custom spring rates on the coilover depending on your application. Koni's I believe has a lifetime warranty so if it breaks, just send it in. You can also do custom revalving, which I strongly suggest, if you decide on stiffer springs.
You can also browse the Roadracing forums and find out what they're using.
northemt88
Oct 7, 2007 05:30 PM
Digitalcivic
Aug 26, 2005 10:53 AM
carracr625
Jul 7, 2004 03:21 PM
likaciv
Jan 11, 2004 12:13 PM
