94ls dc2 to b20z help
Old Mar 25, 2007 | 01:38 PM
oldhand's Avatar
Default 94ls dc2 to b20z help
I just want to say this site is GREAT source of info as I spent almost all day reading about B20's yesterday. Lots of good posts. I just want to make sure my ducks are in a row before I drop any $ and was wanting some opinions. I have a almost stock (i/h/e) 94 ls integra w/5 spd. The tranny is good (worn clutch) but the motor although still running has a dead cylinder. I have found a 21,xxx mile 2000 b20z us crv motor for a good price (still in the crv) and and want some opinions on what to use from the two motors as to have the best setup. This is a DD car and will never have any more then a few blot on's.
Question 1
If i just put a new clutch (ls or gsr) and resurface my ls flywheel it will bolt up properly to the b20 correct?
question 2
I use the ls :intake, injectors, exhaust, pulleys, and dizzy?
From reading I think I can use all my ls parts and just bolt everything on the crv if I am correct? If I use all my ls parts will I have to change any wiring on the ls harness to use this crv motor? Thanks for all the help and for such a great site And if there is anything I am missing on doing this swap please inlighten me.
Old Mar 25, 2007 | 01:40 PM
oldhand's Avatar
Default Re: 94ls dc2 to b20z help (oldhand)
And one last thing I will have about $400 to spend after I purchase the motor, clutch and timing belt. Where would my $ be best spent?
Old Mar 25, 2007 | 01:47 PM
dohcMONSTER's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by oldhand &raquo;</TD></TR><TR><TD CLASS="quote">And one last thing I will have about $400 to spend after I purchase the motor, clutch and timing belt. Where would my $ be best spent?</TD></TR></TABLE>
keep it until all the kinks of the swap are worked out. trust me you will get nickel and dime(d) to death by swaps sometimes
Old Mar 25, 2007 | 01:52 PM
oldhand's Avatar
Default Re: 94ls dc2 to b20z help (dohcMONSTER)
Well gonna keep every penny till I have everything running. Very good advice
Old Mar 25, 2007 | 01:55 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by oldhand &raquo;</TD></TR><TR><TD CLASS="quote"> If i just put a new clutch (ls or gsr) and resurface my ls flywheel it will bolt up properly to the b20 correct? YES
question 2
I use the ls :intake, injectors, exhaust, pulleys, and dizzy? YES
From reading I think I can use all my ls parts and just bolt everything on the crv if I am correct? If I use all my ls parts will I have to change any wiring on the ls harness to use this crv motor? NO, Plug and play with your harness </TD></TR></TABLE>
Old Mar 25, 2007 | 03:13 PM
oldhand's Avatar
So its just the same as putting a b18b if I use all my componets correct? Any thoughts on the computer? Will the motor run lean with the stock ls computer or be fine? Is there anything I would need from the junk yard crv other then the complete head and block? Just want to be 100% sure before I go to the wrecker after I get off work tommorow and get this thing. Thanks a BUNCH!!!
Old Mar 25, 2007 | 04:03 PM
same ECU too
Team_Insane
Engine Management and Tuning
Mar 2, 2010 01:37 PM
KMk51188
Aug 3, 2006 10:13 AM
D16y8_Rebuild
Feb 28, 2006 04:57 PM
SIcoup
28
Sep 24, 2003 03:06 PM
widecoupe
Apr 17, 2003 03:14 PM
