rear drum to rear disk brakes????
Old Mar 25, 2007 | 01:14 PM
crowds's Avatar
Default rear drum to rear disk brakes????
help!!!!!!
Old Mar 25, 2007 | 01:18 PM
crowds's Avatar
Default Re: rear drum to rear disk brakes???? (crowds)
i dont have to drop my gas tank do i??? and any easy way to undo those f-in torx bolts?????
Old Mar 25, 2007 | 02:23 PM
SlowReaction's Avatar
What do you need help with? What kind of car is it? and No you dont need to drop the gas tank.
Old Mar 25, 2007 | 02:33 PM
hatchling37's Avatar
Wow. I'm sure that someone is going to post ***** and tell you to search, but if you're doing a swap onto a Civic, it's super easy. You're gonna need a Tunorx bit, (I think it's a T-50) and use a ratchet or, if you have access, a 3/8 impact. Just undo those four bolts and remove the hub. Then it's just a matter of lining up the holes and tightening up the ****. I'd definitely recommend changing the MC and Proportioning valve if you want the full effect of the new brakes.
Old Mar 25, 2007 | 09:45 PM
88ED8's Avatar
Default Re: rear drum to rear disk brakes???? (hatchling37)
here check this out, should help alot https://honda-tech.com/zerosearch
Old Mar 25, 2007 | 11:19 PM
Default Re: rear drum to rear disk brakes???? (88ED8)
I though he was talking bout swapping out the whole trailing arms.
hmong337
26
Jun 25, 2010 02:30 AM
joelmatt89
Mar 2, 2009 04:21 AM
imadigitalgod
Sep 8, 2006 02:51 PM
Panoply
Aug 4, 2006 07:16 AM
civicminded3111
Jul 9, 2006 08:29 PM
