HELP turn signal lights are NOT WORKING!
Old May 24, 2002 | 02:30 PM
smeister's Avatar
Default HELP turn signal lights are NOT WORKING!
Ok to make it short someone stole my clear corners and i bought new used harnesses for the corner lights. I wired them up...everything worked fine till I tested a wire out to see what would happen and they stopped blinking (short). The thing is the corner lights work when i lock or unlock my car with the alarm, but they will not work with the right or left or emergency signal AND the interior arrows are NOT working anymore. I think it has to do with the interior lights not working and therefore the blinkers aren't neither front or rear. If someone can kindly tell me which FUSE i need to replace under the dash. Id check myself but my friend has my helms manual and he is out of town. Thanks!
CLIFF NOTES: Corner lights are not working after rewiring. Interior arrows are not working in any case. Corner lights do light up when alarm is used. Need to know what FUSE to replace.
sorry for the long cliff notes hahah
TIA
Old May 24, 2002 | 05:36 PM
KooK's Avatar
Mustang Sally
Default Re: HELP turn signal lights are NOT WORKING! (smeister)
two things... Are we talking about a 3rd gen here? And dont you have an owners manual to look up which fuse you gotta replace (If its blown). Normally the interior lights don't work if there is a problem like a bulb is out. What wire were you testing and how did you test it?!?
Old May 24, 2002 | 07:51 PM
MilanoRex's Avatar
Default Re: HELP turn signal lights are NOT WORKING! (Teken)
Teken<---Who doesnt understand why it would be so hard to check a fuse...
it must be cold outside
Old May 24, 2002 | 08:24 PM
Red GSR's Avatar
Default Re: HELP turn signal lights are NOT WORKING! (MilanoRex)
I had the same thing happen to me. I think you will find that your window wipers don't work either. The fuse box under your steering wheel has a map attached to the cover. Grab one of the spare 7.5a fuse and swap it with the interior light fuse. And that should do it.
I just noticed there is a 10a FR right signal fuse as well, you can swap that next if the first one doesn't work.
[Modified by Red GSR, 5:29 AM 5/25/2002]
Old May 24, 2002 | 10:12 PM
smeister's Avatar
Default Re: HELP turn signal lights are NOT WORKING! (KooKaT)
Yeah I realized that I could check the owners manual once my friend reminded me about it. Thanks for responding everying. I do own a 3rd gen and it is TOO HOT to go outside. The sun is burning hot. You people up north should appreciate the cold. heheh...
JDMFEVER
Jun 27, 2008 04:43 PM
tigersball
Jan 28, 2007 10:53 AM
AMBGUOS
Jan 25, 2004 12:04 AM
