Suspension & Brakes Theory, alignment, spring rates....
Koni Yellow spring perch setting (With Eibach Sportline Springs) Question
Old Mar 24, 2007 | 10:40 PM
Rayz_Si's Avatar
From: Land of the Hillbillies and Shotguns, Ontario, Canada
Default Koni Yellow spring perch setting (With Eibach Sportline Springs) Question
Heu guys, I would like to know what is the best spring perch setting on my koni yellows, I have Eibach sportline 1.8" drop lowering springs. I've noticed there are 3 setting, 1-off road, 2-stock, 3-lowest.
I would like to know what you guys recommend.
I would also like to know if I do put it on the "lowest" setting, would that compress the shock more, and decrease the life of my shock, will it be too low??
Old Mar 25, 2007 | 12:08 PM
HondaF1Fanatic's Avatar
Leave the perches in the stock location. The lower location will not work well with lowering springs, and may cause your damper to blow if it is too low. AFAIK the lower position is only really safe for use with stock springs.
Jon
Old Mar 28, 2007 | 10:05 AM
Rayz_Si's Avatar
Default Re: (HondaF1Fanatic)
thanks alot for your help man!!!
Old Mar 28, 2007 | 07:10 PM
Not a problem.
Jon
saemoonyang
Jul 27, 2010 06:20 AM
wannaBjdmca6
Suspension & Brakes
Dec 8, 2009 02:02 PM
variable
Jul 14, 2008 11:04 AM
cmdr430
Honda S2000
10
Apr 17, 2005 11:05 PM
743power
Apr 4, 2003 07:12 AM
