Valves might have bent?
i put a new timing belt on my car....when i started the engine a loud screaching noise came from the engine, which started and ran shakey. i immediately turned the engine off......found out i didn't tighten the belt enough so it started skipping gears. After redoing everything and tightening the belt.....i started the car once again but this time it ran fine. i took the car for a spin and everything seemed all right except, after warmingup, my rpms ran oddly low at idle (about 400pms). Is it possible that i might have bent valves??? i didn't get a chance to do a compression or leakdown test but i was wondering if anbody had some input??
