WTT CLEAN 95 Integra for Del Sol
I want to trade this for a Del Sol.
Stats:
1995 Integra LS
2dr, black/dkgray factory interior (mnrf, pwr windows and mirrors), still has AC
5spd
Exterior:
bg33p factory color (semi-rare, only on 94-97s)
jdm yellow OEM fogs
amber corner lights
'01 integra "mesh" wheels, pretty minty/ tires need replacement
(is now riding on black painted steelies w/"H" center caps w/snow tires)
Performance:
BRAND NEW Exedy stage 1 clutch and resurfaced oem flywheel
OBX greddy-evo style exhaust (2 3/8" stainless)-Not loud, OEM cat is intact
NGK blue wires/ NGK irridium plugs
Poly front sway bar bushings
Poly shifter bushings
Poly motor mount inserts
Interior:
Red gauge cluster and clock
Clarion ProAudio HU
Clarion 2-way speakers all around
OEM tweeters included (not installed)
OEM floormats
Very minty overall
Maintenence:
Car has around 145k mi on it (I'm currently driving about 80-100 miles a day... so this is always changing)
Timing Belt/tensions/water pump/valves adjusted at 120k by honda mechanic (previous owner)
ALL coolant hoses just replaced, many with honda OEM hoses
Headgasket replaced less than 5k miles ago (car never overheated and the coolant never mixed with the oil)
Radiator replaced in August
Thermostat replaced less than 5k ago
Suspension is perfectly tight
Brake master cylinders recently replaced
Slave and cluth master cylinder replaced w/clutch
Distributor has less than 10k mi on it
Nearly new plugs (ngk irridiums)/wires/cap/rotor
Want to trade for....
A DEL SOL!!! (+ at least $1k)
-The Sol must be reliable since I drive 2 hours every day.
Might consider other cars but must have at least $1k on top.
I have no money to put on top of this car...so PLEASE don't ask.
Located in SE PA, 19504.
Stats:
1995 Integra LS
5spd
Exterior:
jdm yellow OEM fogs
amber corner lights
Performance:
Interior:
Clarion ProAudio HU
OEM floormats
Very minty overall
Maintenence:
a del sol, but it has recently received front end damage, so if you see a captiva blue pearl sol with duct tape on the front end thats mine. park mostly in the lot across from the baseball fields.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ICeDoUt »</TD></TR><TR><TD CLASS="quote">a del sol, but it has recently received front end damage, so if you see a captiva blue pearl sol with duct tape on the front end thats mine. park mostly in the lot across from the baseball fields.</TD></TR></TABLE>
I've actually never seen it. Not many Sols on campus, so that's surprising. I'm only there for night classes now and after the summer semester, I'm done forever, thank god.
Danronian
Northeast (Sales)
Apr 6, 2007 05:59 PM
Danronian
Mid-Atlantic (Sales)
10
Apr 5, 2007 03:10 PM
Danronian
Nov 29, 2006 04:22 PM
Danronian
Northeast (Sales)
Nov 12, 2006 06:25 AM
