Clutch cable removal.
Old Mar 24, 2007 | 06:41 PM
Booz's Avatar
Default Clutch cable removal.
How do you get a clutch cable off? I spent a while and all that happened was that the bottom nut kept turning the entire cable and wouldn't come off.
Old Mar 24, 2007 | 09:42 PM
arc_55's Avatar
you should see a platic nut at a bracket hanging off the transmission. back this nut off until there is slack in the cable. There is a slot on the bracket that the cable can slip through and same goes for the fork going into the transmission.
Old Mar 25, 2007 | 05:40 PM
Booz's Avatar
Default Re: (arc_55)
The plastic nut is the problem I'm having getting off. It's a nut that's got a very thin end, like the socket barely fits on it. And everytime I try to turn it, the clutch cable turns to. And it's the same nut that's on the end of the cable connected to the tranny bracket.
Old Mar 25, 2007 | 06:27 PM
Aahj's Avatar
Default Re: (Booz)
You should be able to pull up on the cable housing to loosen tension off of the plastic nut so you can loosen it.
kricket3000
Sep 15, 2009 11:44 AM
ryanevansoh
Mar 23, 2009 02:02 PM
hondacivic0909
Aug 2, 2007 06:05 AM
EKIM NART
Mar 12, 2006 06:06 PM
90civichbsi
12
Sep 9, 2002 06:41 PM
