What the? My clutch engagement changed over night.....
Old Mar 24, 2007 | 02:48 PM
GraphiteMW's Avatar
Default What the? My clutch engagement changed over night.....
So I just went out to go somewhere then I pushed in my clutch and it went in way too easy and my clutch engages when I barely left a inch off the floor board? Any ideas of what happened?
Old Mar 24, 2007 | 03:38 PM
prelude_h22vtec's Avatar
leak in the lines maybe, bad slave or master cylinder. all possibilities
Old Mar 24, 2007 | 03:44 PM
Wsteun's Avatar
Check your fluid.
Old Mar 25, 2007 | 07:17 AM
LudaChris's Avatar
Default Re: (Wsteun)
I'll have to say you have an internal leak in the master cylinder if you can not locate a visible leak in the slave or master cylinder. You can get a rebuild kit for around $20 from Autozone.
Old Mar 25, 2007 | 07:30 AM
GraphiteMW's Avatar
I checked my slave cylinder fluid and somehow it emptied over night ? Well I filled it up, everything worked fine with a few pumps of the clutch pedal and it didn't really leak visibly, I'll check my car out in a few to see if it leaked again.
Old Mar 25, 2007 | 09:26 AM
well the fluid doesnt disappear magically. you have a leak somewhere. keep an eye on that
Civic Racer X 7
11
Aug 27, 2014 05:53 PM
lil vin
Jun 21, 2014 01:30 PM
JDMswagSerf
Dec 10, 2013 09:47 PM
dgerej2
Oct 1, 2009 07:16 AM
lsvtec97hatch
Aug 5, 2009 11:21 AM
