please help: i need to get rear camber fixed.
Old Mar 24, 2007 | 02:09 PM
Hando's Avatar
Default please help: i need to get rear camber fixed.
I dumped my 4th gen and got an alignment. i had the tech zero out the toe in the front and the rear. i still have really bad camber in the rear-- -3 to be exact. i was gonna do the washer trick but just realized that it cant be done on preludes. how can i fix this camber? what do i need--adjustable ball joints, camber kit??? Please help.
Old Mar 30, 2007 | 02:50 PM
K-Litt's Avatar
Default Re: please help: i need to get rear camber fixed. (Hando)
Sounds like a camber kit would work for you. Several companies make them, but the ones I found recently were from Eibach or Ingalls. Hope this helps.
1992 - 1996 BB1/BB2
Front Drop
0" to 1.5"
Adjustable Mounts - Rubber Bushings -3/4° to +1° 35710
Adjustable Mounts - Polyurethane Bushings -3/4° to +1° 35700
Adjustable Mounts - Brass Bushings (Racing Only) -3/4° to +1° 35660
1.5" to 3"
Adjustable Mounts - Rubber Bushings +1-1/4° to +3° 35730
Adjustable Mounts - Polyurethane Bushings +1-1/4° to +3° 35720
Adjustable Mounts - Brass Bushings (Racing Only) +1-1/4° to +3° 35670
Rear Drop
0" to 1.5"
1.5" to 3"
(information gathered from http://www.ingallseng.com/cars/honda.html)
Old Mar 30, 2007 | 03:27 PM
darkspector2.0's Avatar
as long as your toe is zeroed you should be fine.
LS2ner
Suspension & Brakes
Apr 30, 2006 02:15 PM
giff74
Suspension & Brakes
Jul 27, 2005 11:54 PM
kevinoneill
10
Apr 7, 2004 04:29 PM
jisu009
Apr 14, 2003 10:24 AM
RTW DC2R
Oct 8, 2002 05:32 PM
