stalled on fwy wont start!!!
since the fwy incident i replaced the main relay and started right up, drove around block 2 times and noticed a slight hesitation when i get on it. after second lap, stalled and wont start again. replaced relay again and still wont start. replaced the fuel filter and still wont start....90 dx hatch sohc ZC.
this has happened to me b4. check ur ignition rotor. make sure the scew that holds on the dizzy shaft is still there. if seen them fall off and snap off.
i checked the coil and its good. it wasnt getting spark before then i replaced the main relay and it started up. drove it 2 blocks and died. now it wont start again.
skirrrt
14
Nov 6, 2008 09:48 AM
