Anyone connected the clutch bypass switch on a Compustar.....
I've got everything installed on my Compustar CM3000 remote start/alarm but the remote start won't work unless I have the clutch pressed in. I have the black status out wire in CN/2 connected to the yellow plug on the clutch. Inside this plug there is a blue/red and a black/blue wire. I have it connected to the black/'blue wire. There is 12V on that wire but it's not turning over. The lights are coming on and it cycles 3 times but it's not trying to turn over unless I have the clutch pressed in. Is there another wire that needs connected also?
Thoughts?
Thanks again!!
Thoughts?
Thanks again!!
the plug on the clutch pedal bracket that tells the car the clutch is down, my boy just cut those two wires and hooked them together to bypass that swtich
melissashelton1
Dec 26, 2009 04:37 AM
compint
Mar 13, 2007 10:42 PM
Circuit8
Audio / Security / Video
May 8, 2003 07:23 AM
