sequential gearbox for civic?
xtrac ? http://www.xtrac.com/mainindex.htm
gforce ? http://www.gforcetransmissions.com/
maybe you would be interested in some Libertys Gears?
http://www.libertysgears.com
xtrac is the choice! They manufacture transmissions to very high standards. It is a flawless trans that will take a pounding. I did the first install of one years ago in Gary Gardella's Civic. Depending on clutch choice there are different bellhousings that are needed. I built the bell housing in gary's car so that we could run a slipper(although the clutch never really worked as a slipper). The starter was relocated to the side of the engine rather then having it hang off the back of the bell so that a clutch access cover could be made and other clearance issues for the clutch. I also built the shifter for several of the cars that ended up running the trans Gary's with a ignition break switch built in and the pthers used strain gauge on the linkage.
i think i will shorten up your search a little bye telling you those trannys are in the neihborhood of 10-15,000 when said and done. on that note are you interested in buying a stock r tranny
Quaife makes an awesome tranny for the nice price of $18,000
http://www.autotech.com/quaife/index2.htm
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ivt-t »</TD></TR><TR><TD CLASS="quote">I dont think that i want spend 20k $ for tranny...
so pass then</TD></TR></TABLE>
how much did you "think" they went for?
From: gravity rides everything...everything will fall, se GA/ne FL
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by KFMRC »</TD></TR><TR><TD CLASS="quote">I also built the shifter for several of the cars that ended up running the trans Gary's with a ignition break switch built in and the pthers used strain gauge on the linkage.
do you have a pic of this you wouldn't mind sharing? strain gauge is the same thing as a linear pressure switch that senses push or pulling? thanks.
i know i been out of the racing game for a while but what the hell is that?<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by exospeedAMcrx »</TD></TR><TR><TD CLASS="quote">
Not a transmission but,
I wanted to put this in my CRX, but they said it was for Hot Rods only. heheh
that is the knight rider stearing wheel.
</TD></TR></TABLE>that is the knight rider stearing wheel.
Because its the only gearsets that are affordable and have been tested by 7 sec cars. They still break a gear here and there but its not gonna get any better for something that utilizes a stock case. Someone like yourself will prolly never break them unless your making as much power as umm only 5 other hondas in the country are.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Supernatural »</TD></TR><TR><TD CLASS="quote">i know i been out of the racing game for a while but what the hell is that?</TD></TR></TABLE>
i believe its a wireless paddle shifter
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Arturbo »</TD></TR><TR><TD CLASS="quote">
that is the knight rider stearing wheel.</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HR-1320 »</TD></TR><TR><TD CLASS="quote">Because its the only gearsets that are affordable and have been tested by 7 sec cars. They still break a gear here and there but its not gonna get any better for something that utilizes a stock case. Someone like yourself will prolly never break them unless your making as much power as umm only 5 other hondas in the country are.</TD></TR></TABLE>
i have seen numerous sfwd guys break libertys gears. there are other gears out there that are stronger than liberty and goes into a stock box!
would liberty gears be good for an all motor application or would sequential be good? im specifically talking b-series. i dont think anyone ever went sequential with a N/A b-series. i may be wrong.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by N.Y.C.E. »</TD></TR><TR><TD CLASS="quote">
i have seen numerous sfwd guys break libertys gears. there are other gears out there that are stronger than liberty and goes into a stock box!</TD></TR></TABLE>
More info please
More info please
