crank pulley removal
Old Mar 23, 2007 | 11:21 PM
lacking vtec's Avatar
Default crank pulley removal
so i've been trying to get the damn crank pulley off for the past 2 hours now but to no avail. i managed to get the bolt off with the crowbar trick. but the pulley is still stubbornly attached and i dont see any other bolts holding it in place. what am i doing wrong? im about to get my rubber mallet and start wackin the damn thing loose.
Old Mar 23, 2007 | 11:53 PM
Dealer Leaf's Avatar
Default Re: crank pulley removal (FlipTheHater)
This would be the easy way:
(Its a bitch! Use an impact gun. I had to impact gun mine for about 5 minutes off and on to get it off.
Dont worry if you think your tightening it cause its normal threads not lefthanded backwards crap.)
And as for your problem, the key is probally wedged in good which impact gun woulda loosened up but I guess try a breaker bar or crow bar between the block and pulley. Assuming you have removed the all the timing belt covers you shouldnt have to worry about breaking anything in that area. Just use a piece of wood so that you dont scratch your block if your that concerned.
Another Alternitive:
Tie a rope around the pulley so that it wont slip off, and use a ratchet winch or muscle power and yank it off
I would put the bolt back and and give it a lil impact gunnin to loosen it up
Old Mar 24, 2007 | 04:36 AM
Default Re: crank pulley removal (Dealer Leaf)
that's the thing, i dont have an impact gun. i'll prolly try and pry it off w/ the crow bar or somethin
Old Mar 24, 2007 | 04:55 AM
j_bizach's Avatar
coke! thats the trick coke-a-cola same thing happened top me call up my dad to help me come walking in with a coke opens it up and dumps it on the pulley (at this time im pissed but) 5 min later i pulled it off with couple taps of the hammer. Its a preaty stick clean up, brake cleaner works good.
6_Speed
Aug 18, 2020 06:02 PM
DX_JDM_HATCH
14
Jun 4, 2013 06:55 AM
MurtazaDSM
Mar 18, 2012 01:14 PM
tealchief
10
Mar 31, 2009 04:40 AM
Lei Siew Long
Sep 11, 2001 11:39 AM
