Whats included in the 30K service
Old May 24, 2002 | 12:07 PM
type r 01-1063's Avatar
Default Whats included in the 30K service
the dealer just faxed me the invoice right now and it reads....
"30,000 MILE SERVICE-LUBE, OIL & FILTER CHANGE, REPLACE DRAIN PLUG
GASKET, CHECK/ADJUST FLUID LEVELS/DRAIN & REFILL
TRANSMISSION, REPLACE AIR & FUEL FILTERS, ROTATE & SET TIRE
PRESSURE, INSPECT BRAKES & FLUSH SYSTEM. (SPARK PLUGS & COOLANT
EXTRA).
What i dont see in here is front and rear wheel alignment. shouldn't that be included?
i already did a search and its not helping. also, i checked out http://www.itrsport.com for reference but it seems to be down at the moment.
Old May 24, 2002 | 12:15 PM
uNF$@#!'s Avatar
Default Re: Whats included in the 30K service (type r 01-1063)
i will reply with an entire listing a little later...
Old May 24, 2002 | 01:45 PM
bump
Old May 24, 2002 | 03:29 PM
JoshRambo's Avatar
valve adjustment and 4 wheel alignment as well
Old May 24, 2002 | 05:20 PM
PiYoImuT's Avatar
Default Re: Whats included in the 30K service (Gravity)
Hm.. other than Valve Adjustment.. I have been doing all that is included in your list of 30K maintenance every 10K miles..
mine is at 24K now...
I guess I won't be needing a 30K services then..
[Modified by PiYoImuT, 9:20 PM 5/24/2002]
Old May 24, 2002 | 05:29 PM
TypeR_853's Avatar
30,000 Mile Service (Repeated at 60000, 90000, 120000, ETC.)
Includes All Items of 15,000 Service Above Except Flushing of Anti-Freeze
Plus the Following
Service Anti-Lock Brake System (Except RS)
Change Brake Fluid
Inspect Exhaust System
Adjust Alternator and Power Steering Belts
Change Transmission Fluid
Replace Air Filter
Replace Spark Plugs (GS-R and Type R Every 60,000 Miles
Replace Ignition Cap and Rotor (Except Cap at 30,000)
Replace Fuel Filter
taken from http://members.aol.com/josh3030/maintenance.html
[Modified by TypeR_853, 6:30 PM 5/24/2002]
Old May 24, 2002 | 07:41 PM
98R-1003 US's Avatar
Default Re: Whats included in the 30K service (TypeR_853)
You forgot "huge dealer markup"...
I pay it anyway, but I grumble... There's just so many minor things that don't seem to add up to the price. I try to remember that car washes and loaner cars aren't really free...
KrazyDawg
Mar 18, 2008 04:39 PM
MachAF
Jul 22, 2005 01:35 PM
Tarmac Pro
Oct 10, 2003 11:22 AM
SonicGSR
Oct 9, 2002 08:16 PM
SonicGSR
Oct 9, 2002 07:28 PM
