DIY Lower Ball Joint Change
Old Mar 23, 2007 | 08:06 PM
92hondalude's Avatar
Default DIY Lower Ball Joint Change
Click Here for the write up.
By: Nick Burden (92hondalude)
Modified by 92hondalude at 8:33 AM 1/7/2008
Modified by 92hondalude at 8:34 AM 1/7/2008
Old Mar 23, 2007 | 08:17 PM
manbearpig's Avatar
Default Re: DIY Lower Ball Joint Change (92hondalude)
just the way a write up should be
Old Mar 23, 2007 | 08:23 PM
GraphiteMW's Avatar
Wow, nice write up, actually shows everything haha.. How much does a lower ball joint cost? Mine is pretty much cracked and deteroiating.
Old Mar 23, 2007 | 08:31 PM
Default Re: (GraphiteMW)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GraphiteMW &raquo;</TD></TR><TR><TD CLASS="quote">Wow, nice write up, actually shows everything haha.. How much does a lower ball joint cost? Mine is pretty much cracked and deteroiating.</TD></TR></TABLE>
Mine was around $30 for both. I think i found a deal
Old Mar 23, 2007 | 08:33 PM
ECX's Avatar
ECX
* B A N N E D *
Default Re: DIY Lower Ball Joint Change (joinerneal)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by joinerneal &raquo;</TD></TR><TR><TD CLASS="quote">just the way a write up should be </TD></TR></TABLE>
Old Mar 23, 2007 | 08:55 PM
bb_one's Avatar
Default Re: DIY Lower Ball Joint Change (ECX)
Where did you get your ball joint press? Or a part number?
Great write up
Old Mar 23, 2007 | 08:57 PM
Default Re: DIY Lower Ball Joint Change (bb_one)
Advance.
Part # 648617
Old Mar 23, 2007 | 09:01 PM
93sivtec's Avatar
I need to do this.....mine are shot.Did u notice a difference with the new ones?And yes where did u get the press?Thanks
Old Mar 23, 2007 | 09:05 PM
Default Re: (93sivtec)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93sivtec &raquo;</TD></TR><TR><TD CLASS="quote">I need to do this.....mine are shot.Did u notice a difference with the new ones?And yes where did u get the press?Thanks</TD></TR></TABLE>
Yes it cleaned up the streeting alot. But as you can see mine were way overdue.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92hondalude &raquo;</TD></TR><TR><TD CLASS="quote">Advance.
Part # 648617</TD></TR></TABLE>
Old Mar 23, 2007 | 09:08 PM
bb_one's Avatar
Thank you!
This should be put in the FAQ's.
Old Mar 23, 2007 | 09:11 PM
roller3804's Avatar
great write up. FAQ it
Old Mar 23, 2007 | 09:19 PM
DfwBB6's Avatar
Default Re: (roller3804)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by roller3804 &raquo;</TD></TR><TR><TD CLASS="quote">great write up. FAQ it</TD></TR></TABLE>
absolutely
Old Mar 23, 2007 | 09:23 PM
Default Re: (DfwBB6)
i just asked. Thanks Guys
Old Mar 23, 2007 | 09:25 PM
bb_one's Avatar
For anyone looking for lower ball joints, these seem to be good alternative to OEM
http://cgi.ebay.com/ebaymotors...ZWD1V
Other memebers including myself have had good expriences with "bestsuspension/ World Suspension" before. I am not affiliated with them by any means.
Old Mar 23, 2007 | 09:26 PM
Default Re: (bb_one)
haha thats the ones i got
they are good.
only problem is the nut they give you is a 21mm instead of 19mm
Old Mar 23, 2007 | 09:37 PM
bb_one's Avatar
Default Re: (92hondalude)
Is it the same thread/pitch though?
Old Mar 23, 2007 | 09:51 PM
not sure i didnt try the old nuts on the new ones. those old nuts were messed up anyway.
Old Mar 23, 2007 | 10:40 PM
93sivtec's Avatar
Belive it or not....mine are probally worse.
Old Mar 23, 2007 | 10:55 PM
thegeorge613's Avatar
Great write up. What shocks are those, anyways?
Old Mar 23, 2007 | 11:02 PM
93sivtec's Avatar
tokico hp it looks like
Old Mar 23, 2007 | 11:12 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93sivtec &raquo;</TD></TR><TR><TD CLASS="quote">tokico hp it looks like</TD></TR></TABLE>
You think so? I think those look like Bilsteins, not sure though.
Old Mar 24, 2007 | 05:23 AM
Default Re: (thegeorge613)
correct.
i want to upgrade to tokico illumina
Old Mar 24, 2007 | 09:15 AM
Montx's Avatar
I don't understand the necessity of removing the damper fork bolt and the strut bolt at the top?
I know on my 88 4WS all I have to do is unbolt the Upper Ball Joint from the UCA ( still leaving it attach ed to the spindle) and the outer tie-rod from the spindle and pop the lower ball joint and it gives you enough to take the spindle off.
Old Mar 24, 2007 | 10:02 AM
pentaq's Avatar
Default Re: (Montx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Montx &raquo;</TD></TR><TR><TD CLASS="quote">I don't understand the necessity of removing the damper fork bolt and the strut bolt at the top?
If you don't, the pressure from the spring and shock will not allow you to pull the joint out from the control arm.
Old Mar 24, 2007 | 10:24 AM
Montx's Avatar
Well I do it all the time the way I stated and it works, so I guess what ever you gotta do, you have to do!
