y8 manifold on a y7 engine
Old Mar 23, 2007 | 06:33 PM
jahasiel's Avatar
Default y8 manifold on a y7 engine
i plan to swap a y8 exhaust manifold to a y7 engine, so my question is , all i need is the manifold or do i have to buy something else to make the swap?, any help really appreciated
Old Mar 23, 2007 | 06:52 PM
B serious's Avatar
Cool Cool Island Breezes. BOY-EE
Default Re: y8 manifold on a y7 engine (jahasiel)
make sure it comes with the IAC, and the IAC plug for a y8. You will need to rewire the IAC. The IAC in the y8 is 2 wire, while the y7 has a 3 wire. There's one wire that gets deleted....i cant remember which one. I wanna say the orange one, but im not 100%
Old Mar 23, 2007 | 07:48 PM
zerovandez's Avatar
I don't think he's swapping a motor. Sounds more like just the exhaust manifold.
Anyways, the D16y7 exhaust mani has a cat converter directly connected to it. If you swap it with a y8, you'll also need a catalytic converter and extend the 2 o2 sensors if needed. The y8 exhaust mani will reach the "B" pipe but then you'll have no cat, so you'll need to have a muffer shop fit one in there. Good luck.
Old Mar 24, 2007 | 02:49 PM
B serious's Avatar
Default Re: (zerovandez)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by zerovandez &raquo;</TD></TR><TR><TD CLASS="quote">I don't think he's swapping a motor. Sounds more like just the exhaust manifold.
Anyways, the D16y7 exhaust mani has a cat converter directly connected to it. If you swap it with a y8, you'll also need a catalytic converter and extend the 2 o2 sensors if needed. The y8 exhaust mani will reach the "B" pipe but then you'll have no cat, so you'll need to have a muffer shop fit one in there. Good luck.</TD></TR></TABLE>
WHOOPS lol i thought i read intake manifold. sorry.
You'll need a cat from an EX if you want no check engine light. Use a cat, dont be a jerk.
freddy chavez
14
May 30, 2013 08:55 PM
civicawesome
15
Jan 27, 2013 10:36 AM
Team_Insane
May 12, 2011 08:25 PM
92civic_eg
Aug 18, 2004 06:24 PM
