help with changin the Timing Belt and water pump ..!!!!!!!
Old Mar 23, 2007 | 06:27 PM
DJNauTicz's Avatar
Default help with changin the Timing Belt and water pump ..!!!!!!!
i need help to change the timing belt and water PUMP..please HELP!!!!!
anyone got a DIY how to DO the change..please help
Old Mar 23, 2007 | 06:31 PM
B serious's Avatar
Cool Cool Island Breezes. BOY-EE
Default Re: help with changin the Timing Belt and water pump ..!!!!!!! (DJNauTicz)
buy a helms manual or get a diagram from a honda dealer. If you're nice, they give you the diagrams and instructions.
Old Mar 23, 2007 | 07:23 PM
DJNauTicz's Avatar
Default Re: help with changin the Timing Belt and water pump ..!!!!!!! (B serious)
yea..saw some online..it's hard to change it my self??
Old Mar 24, 2007 | 09:37 AM
Sam92Teg's Avatar
The two most difficult parts of swapping the timing belt, tensionor, and water pump;
First, is removing the crank pulley bolt. I took mine to a local shop and had them loosen then retighten for me. No charge. Then I already had purchased a crank pulley tool that holds your crank pulley with a breaker bar to keep it from spinning while you remove the bolt with another breaker bar and a socket. If you have a decent impact wrench, forget this first item.
Second, is timing the cams properly after the belt is installed. It must be perfect. I have a non-vtec B18A that allows you to use dowels to hold the cams in place while at TDC. Helps some, but the tension from the valve springs still makes it difficult.
Good luck and buy a $15 Haynes manual from your local auto parts store.
Old Mar 24, 2007 | 10:26 AM
integra686's Avatar
Default Re: help with changin the Timing Belt and water pump ..!!!!!!! (Sam92Teg)
make sure u loosen the top right motor mount a lil. it help with the crank pully belt
Old Mar 24, 2007 | 10:45 AM
Benhawk's Avatar
Default Re: help with changin the Timing Belt and water pump ..!!!!!!! (integra686)
Here is a good 7 page color photo guidline, but you should really use a Helms manuel as well, I found this to be helpful.
http://www.team-integra.net/se...=1044
Old Mar 24, 2007 | 10:50 AM
Benhawk's Avatar
Default Re: help with changin the Timing Belt and water pump ..!!!!!!! (Benhawk)
I found with instead of using a dowl pin on the intake side, I used vice grips with tape on them. This helped me to keep the dash marks on the cam gears lined up, as the intake side seemed to be under a little pressure. The exhaust side I was able to use a 3/8" dowl pin ( correct me if I am wrong, it may be smaller) to keep the cam gears lined up properly, as it wasn't under any pressure. Just make sure your four dash marks on the cam gears are lined up, and you are good to go. It took me more than one try.
Old Mar 25, 2007 | 09:22 AM
DJNauTicz's Avatar
thanks u think is better do it my self or take it to the shop?
Old Mar 25, 2007 | 09:56 AM
vinai's Avatar
If you are not confident in your abilities you should take it to a shop. Many things can go wrong with changing the timing belt and water pump. The tensioner bolt can be a real pain, and some times it will just come off with minimal effort. If you have the time do it your self give your self the day and definitely have help. The first one I did by my self and it pretty much sucked.
Old Mar 25, 2007 | 01:23 PM
Benhawk's Avatar
Default Re: help with changin the Timing Belt and water pump ..!!!!!!! (vinai)
I agree, the first one was a pain. It took me the whole weekend, plus a few hours, but I did a valve lash adjustment as well. The hardest part was locking the intake cam in place to keep everything lined up. The exhaust side was easy, but like I mentioned before, the intake side can be tricky, if you don't have a cam locker.
If you are second guessing yourself, I would take it somewhere. I also advise to use an impact gun to remove the nut holding your crank pully on.
Old Mar 26, 2007 | 08:28 AM
B serious's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Benhawk &raquo;</TD></TR><TR><TD CLASS="quote">I agree, the first one was a pain. It took me the whole weekend, plus a few hours, but I did a valve lash adjustment as well. The hardest part was locking the intake cam in place to keep everything lined up. The exhaust side was easy, but like I mentioned before, the intake side can be tricky, if you don't have a cam locker.
If you are second guessing yourself, I would take it somewhere. I also advise to use an impact gun to remove the nut holding your crank pully on.</TD></TR></TABLE>
Well for the crank pulley, you could just put it in 5th/park, and have someone hold the brakes. Then just use a breaker bar.
But yeah its not something you wanna guess or mess up on....you're working on an interference motor, so the timing is crucial.
Old Mar 26, 2007 | 08:36 AM
fergy016's Avatar
Write up from Team-Integra
or
c-speed racing how to
These should give you an idea.
Old Mar 26, 2007 | 10:04 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B serious &raquo;</TD></TR><TR><TD CLASS="quote">
But yeah its not something you wanna guess or mess up on....you're working on an interference motor, so the timing is crucial. </TD></TR></TABLE>
I tried that on my brother's del Sol when tightening the pulley bolt to spec. Even with the car in gear (any gear) and him holding the brakes, the engine still would turn backwards slightly when I tried to tighten it. I ended up just using my impact wrench on a lower setting to tighten it.
[713]
Dec 2, 2009 07:51 PM
vagrnt
May 2, 2007 12:53 PM
S2KILLA
Aug 3, 2006 07:45 AM
mr98accord
May 28, 2003 10:00 AM
drjondurst
10
Mar 10, 2003 04:23 AM
