D16z6 into 92 dx, axles too short? (yea I searched)
Old Mar 23, 2007 | 05:55 PM
teal_dx's Avatar
Default D16z6 into 92 dx, axles too short? (yea I searched)
My car is a 92 dx that had an automatic tranny with a D15b7 motor.
I swapped in a D16z6 (92 si motor) with manual tranny. The manual axles came with the swap (although manual and auto axles should be the same).
So the D16z6 and manual tranny is in now and I used the axles that came with the motor, but each axle is about 1" short.
So I compared to my original axles from my auto tranny and they are the same size, also short. I even have axles from another D16z6, and they are the exact same as the first ones i installed.
I'm sure everything is together right and the axles are pushed all the way into the tranny. I have never heard of this happening before... this should all be a direct swap right?
Am I missing anything, I don't need to swap the control arms or knuckles from a 92-95 si do I?
Old Mar 23, 2007 | 06:07 PM
teal_dx's Avatar
Default Re: D16z6 into 92 dx, axles too short? (teal_dx)
just checked hondaautomotiveparts.com and found out that the knuckles are exactly the same on the 1.5L auto dx and 1.6 manual si... now I'm really stumped
Old Mar 23, 2007 | 09:07 PM
hatchi's Avatar
are you sure that the axles are seated to the tranny??
Old Mar 23, 2007 | 09:17 PM
teal_dx's Avatar
Default Re: D16z6 into 92 dx, axles too short? (hatchi)
yeah, here are some pics I took:
Left axle pushed in completely:
I stretched it out so the threads came through the knucke and tightened the axle nut just to see...
and it reaches, but the boot is so stretched... that can't be good
same for the right side:
when I pulled the end thru the knuckle and tightened the nut:
gen2tegboi
16
May 1, 2011 05:51 PM
phrack3r
Feb 2, 2010 08:29 PM
s10cky
Jan 15, 2006 05:51 PM
2fast4u831
Feb 11, 2004 03:26 PM
