MY CIVIC WITH B16A BOGING
Old Mar 23, 2007 | 05:03 PM
LITTLERIGGY_b16A's Avatar
Default MY CIVIC WITH B16A BOGING
MY 1991 CIVIC WITH A B16A ENGEN IN IT WHAN I BOUT IT IT RAN FIN I HAD THE CAR FOR TO DAYS AND THE CAR STARED TO BOG RELLY RELLY BAD LIKE I GET IT STARED AND PRESS THE GAS IF I PRES THE GAS PEDIL RELLS SLOW THE CAR WILL REV UP IF I KEEP PRESSING IT SLOW AND GET THE REV TO A BOUT 5000 RPM AND THAN PUNCHIT IT WILL BOG DOWN TILL THE PONT WHAN IT WILL SHUT IT SELF OFF SOME TIMES WHAN I GET IN TO THE CAR AND TRY TO START IT I WILL HAVE TO PUMP THE GAS PEDIL RAPEDLEY TO GET IT GOING WHAN IT FERST START IT WILL IDEL AT 1700 RPM THAN WHAN IT WORMS IT WILL IDIL AT 1000 RPM TO 1200 RPM AND IF I REV IT TO 5500 RPM AND DUMP THE CLUCH THE CAR JUST BOGS DOWN AND DYES CAN ANEY ON HELP ME EMAIL ME @ LITTLERIGGY@HOTMAIL.COM PLES I NEEED TO GET THIS CAR GOING O AND ITS A B16A 1.6 DOHC VTEC
Old Mar 24, 2007 | 09:14 AM
civicstar's Avatar
Default Re: MY CIVIC WITH B16A BOGING (LITTLERIGGY_b16A)
common things to check
cap
rotar
wires
spark plugs
fuel filter
distributor
fuel pump
Old Mar 24, 2007 | 04:04 PM
deftonerider's Avatar
did you install the rotor backwards in the distributor, or the distributor 180 into the motor, cris cross the spark plug wires
if those are right then check everything that civic star said
Old Mar 26, 2007 | 05:03 PM
Default Re: MY CIVIC WITH B16A BOGING (civicstar)
i changeed the plugs and fuel feltter and the cap good and wire are to i just took it to my macanic to day so will see ill let you guys no tom
Old Mar 26, 2007 | 05:23 PM
abusedhusband's Avatar
try changing the fuel filter
fastlimegreencivic
Mar 23, 2013 05:34 PM
fastlimegreencivic
Dec 25, 2012 12:01 AM
VTECengaged
Dec 14, 2006 11:02 AM
wrXtian
21
Aug 9, 2005 03:47 PM
andym6956
Nov 25, 2003 06:55 AM
