cam degree of itr cams
Old Mar 23, 2007 | 03:14 PM
myallmotoreg's Avatar
Default cam degree of itr cams
I need to degree my cams in a 97 jdm itr motor. As I understand the peak lift of of your cams need to be at a certain degree relevant to the crank. What is that degree? for both cams. please help
Old Mar 26, 2007 | 09:34 PM
ITR#132's Avatar
Default Re: cam degree of itr cams (myallmotoreg)
just align the holes in the camshaft with the holes in the oil bar.
Old Mar 27, 2007 | 05:09 AM
RagingAngel's Avatar
Try posting up in the all motor forum.
there's a bunch of guys there who should know the specs you're looking for.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ITR#132 &raquo;</TD></TR><TR><TD CLASS="quote">just align the holes in the camshaft with the holes in the oil bar. </TD></TR></TABLE>
I expected more out of a long time member.... what if the OP had the deck and/or the head milled? Ever consider how that will affect timing overall?
Old Mar 27, 2007 | 06:16 AM
HYREV2NR's Avatar
Default Re: cam degree of itr cams (RagingAngel)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RagingAngel &raquo;</TD></TR><TR><TD CLASS="quote">Try posting up in the all motor forum.
</TD></TR></TABLE>^^^^^^^^^^What he said. Tons of cam gear heads in there.
Old Mar 27, 2007 | 09:08 PM
ITR#132's Avatar
I had my head milled, block decked, and different thickness head gasket and heres what I did:
-turn the crank until the crank pulley lines up with the mark on cover and verified piston position
-line up cam gears and install timing belt
-loosen adjusting bolts on cam gears
-turn the cams to align holes in cams with holes in oil bar
It ends up that my cam gears is set at +4in, +4ex. (Its the same as 0in, 0ex on a stock unmolested motor)
Does that not work to set the cams where they are suppose to be? How will it affect timing overall?
Old Mar 28, 2007 | 02:09 AM
Default Re: cam degree of itr cams (ITR#132)
that's more along the lines of what I was expecting out of a long time member...
It's better than just throwing things on as there is a method to your finding out the relative timing vs. your milling.
If the OP has a fixture to degree the cams, he still is looking for the missing information on peak lift.
Old Mar 28, 2007 | 01:21 PM
thanks guys, my head is milled 10 thou and its going to be a month before i can get on a dyno so i just wanted to degree my cams at 0,0 as a base start point. I heard that evan a stock motor could be off a little so its always a good idea to do it anyways. I have posted it in the all motor forum twice and got nothing. please help i need the numbers.
Evilparadize
Apr 30, 2008 04:50 PM
mrbutters
Apr 28, 2008 10:41 AM
camlob
46
May 15, 2006 04:46 PM
MenaceL.A.671
Apr 5, 2006 10:29 PM
beaneg6
Jan 17, 2006 06:59 PM
