p28 ecu on a b18c-r question about chip
Old Mar 23, 2007 | 02:37 PM
Chicano's Avatar
Default p28 ecu on a b18c-r question about chip
So I have a 93 civic si with a p28 chipped ecu (bought it that way) and vtec engages at 4500(only has aem cam gears and intake and exhaust, stock mani) and I really don't feel a boost of power compared to my old gsr eg I use to have when vtec kicked at 5300.
Should I trade for a stock p28 and then have it chipped and tuned or would a stock ecu just slow the car down?
Help appreciated.
Old Mar 24, 2007 | 10:07 PM
mtber's Avatar
Default Re: p28 ecu on a b18c-r question about chip (Chicano)
The program your "chipped" ecu has is probably some garbage ebay chip that runs rich as hell & throws needless amounts of timing into your motor.
Your ecu is probably socketed.
To check watch the video on how to remove/install an eprom chip listed on http://phearable.net/tech
If it is, you can simply install another chip with a proper map for your motor/setup.
wtsapexipowerfc
Engine Management and Tuning
Oct 2, 2010 06:47 AM
azn99si530
Mar 22, 2007 06:33 PM
eeyore357
Nov 12, 2004 05:40 AM
Mike Ockhurts
14
Oct 24, 2003 07:09 AM
