Help: Shifter Bushing/Cable Bushing Install RSX
the shifter bushings they go at the base of the shifter replacing the 4 rubber bushings. Take out the rubber bushings and put these in place. the other bushings the cable bushings go under your hood. They are located under your intake box. I dont have any pictures but maybe a search would help. But you gotta remove those rubber ones as well.
the gold bushings do not go on the shift box, they go under your hood, where the shift linkage is. You replace the old shift linkage bushings with these. If you have a CAI the bushings will be easy to replace. If you have a short ram or a stock airbox, you might have to remove it in order to install them. hope this helps
square_1
Jan 31, 2009 09:26 PM
spoonlongblock
Honda Civic (2006 - 2015)
13
Nov 24, 2006 04:28 AM
