Koni Yellow vs. KYB AGX
Old Mar 23, 2007 | 09:36 AM
sanimalp's Avatar
$cat /dev/urandom
Default Koni Yellow vs. KYB AGX
Ive done a lot of searching and reading, and the general consensus seems to be toward Koni Yellows Over KYB AGX's. From what I can find between the sponsor forum and the general internet is that Koni Yellows are cheaper anyway, which works out for me. Pretend for the moment that money is out of the question, but i would still like to stay in the same class of damper adjustability.
My setup currently is bone stock, and I intend to run my stock springs for now. I eventually may go to lowering springs, but those are very back burner at this point. I intend to do some autocrossing in the future, but my car is still very much my DD. Which one would you vote for given the criteria, and let me know if I'm missing some dampers that fit into the same performance class as AGX or yellows.
Old Mar 23, 2007 | 09:40 AM
Spaceballsthelunchbox's Avatar
No Big Whoop
Default Re: Koni Yellow vs. KYB AGX (sanimalp)
Had them both. The konis are infititely adjustable , meaning there are no preset adjustment points like the AGX which have 4 or 5 not sure.
Also, the konis have and adjustable ( slotted) spring perch which allows you to play with the car's height.
I say go with Konis, plus their warranty service is excellent, not to say that AGX has a bad warranty, I never needed it.
Old Mar 23, 2007 | 09:45 AM
Loserkidwac's Avatar
Default Re: Koni Yellow vs. KYB AGX (Maxbore.com)
I think Konis are the best dampener you can get!!!
I have Koni yellows with Ground controls and I love the set-up...I say either go with that or grab some Eibach springs also have heard good things about H&R springs but have no personal experience with them and you are set
Old Mar 23, 2007 | 11:13 AM
CRX Toad's Avatar
Default Re: Koni Yellow vs. KYB AGX (Loserkidwac)
Koni
Old Mar 23, 2007 | 11:31 AM
CRXBart's Avatar
Are you serious? Is it even a question? If you want some AGxes I'll sell you mine, I'm switching to Koni, and this isn't a for sale add. I'm just stating the Koni is undoubtedly 100x's better. The best is the Koni SPSS twin valves. That is what I'm saving for.
Old Mar 23, 2007 | 11:57 AM
Ass$nyper's Avatar
Pirate General...YARRRR
Default Re: Koni Yellow vs. KYB AGX (CRXBart)
Koni, it shouldn't even be compared to a Keep Ya Bouncing product.
That's like comparing some ripple to a 45 Madeira, i'm offended.
Old Mar 23, 2007 | 12:08 PM
saikouEF8's Avatar
i rock agx and gc... to me its a smooth cost effective ride for a dd setup. power and weight transfer is smooth and dampening is not bouncy at all. the adjustability makes for some noticable changes if u wanna stiffen up the ride for twistys or racing... i like them a lot... personally wherever i looked konis were more money... i was happy with my gr2s so for the new setup i bought the agx....im just that type of person. koni just wasnt worth it to me. im the 1 agx vote lol. i just upgraded my wheels to white 15x8 motegi mr12s i got used and 205/50/15 tires...no gaps no rubbing. just need to take a new pic.
Old Mar 23, 2007 | 12:21 PM
SIred91's Avatar
Rainman
Default Re: Koni Yellow vs. KYB AGX (saikouEF8)
Koni.
Why is this even a question for you?
Old Mar 23, 2007 | 12:24 PM
Tyson's Avatar
if its a question to you, then you should just buy AGX and forget the konis.
koni yellows are definately not cheaper than agx.
illumina > agx.
Old Mar 23, 2007 | 12:42 PM
SIred91's Avatar
Rainman
Default Re: Koni Yellow vs. KYB AGX (Tyson)
Koni sports>illumina>agx
Old Mar 23, 2007 | 01:56 PM
Sho Pow's Avatar
Koni
Ive got koni yellows with h&r springs and I love them. Many of people have commented on the ride quality of my car also. Koni all the way
Old Mar 23, 2007 | 02:08 PM
sanimalp's Avatar
$cat /dev/urandom
Default Re: Koni Yellow vs. KYB AGX (SIred91)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SIred91 &raquo;</TD></TR><TR><TD CLASS="quote">
Why is this even a question for you?</TD></TR></TABLE>
In my search, most threads seem to compare both together and people go either way on them. I know now that yellows are absolutely the way to go.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tyson &raquo;</TD></TR><TR><TD CLASS="quote">
I found these... http://www.nolimitmotorsport.c...66SP4 but didn't realize they were per damper and not a set of fronts. and then I found the AGX as a whole set for $450... so I thought I would be paying ~$300 for koni's instead of $500.
I also didn't realize that Koni's were continuously variable, unlike the AGX. All the item descriptors on the websites i check out were pretty vague about just HOW adjustable these things were.
Looks like I'll be getting Koni's after all. Thanks for the help.
Old Mar 23, 2007 | 03:44 PM
gringo7718's Avatar
1. Figure out what you will be using the car for and what you expect from the suspension. (DD and some Auto-X)
2. Select a lowering spring based on how stiff the spring rates are and how low is an acceptable ride height for your use.
3. THEN match the shocks to the springs you will be using. shocks job is to control the spring.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SIred91 &raquo;</TD></TR><TR><TD CLASS="quote">Koni sports&gt;illumina&gt;agx</TD></TR></TABLE>
END THREAD/
Old Mar 25, 2007 | 08:19 PM
CRXBart's Avatar
the best!
Old Mar 26, 2007 | 06:28 AM
import2nr88's Avatar
/\ that's what I am running and I absolutly love them. Race Koni's with customr Ground Control rates. For 90% of the people out there koni yellows will do more than they need.
Old Mar 26, 2007 | 07:00 AM
91efhondacivicsiNApowa's Avatar
Default Re: (import2nr88)
Ya i have koni yellows as well on my 91 si and its a great ride just need tires to really test it out.
Old Mar 26, 2007 | 10:09 AM
RSZero1's Avatar
Default Re: (91efhondacivicsiNApowa)
Have you ever seen those ads in any car mag, where the owner lists all sorts of numbers on how many wheels, exhausts, chips, etc they go through, but only 1 set of Koni's?
It's like that, once you go Koni, you never think about it again. On full soft, the ride is very nice, predictible and perfect for taking you grandma to church in, but turn them up, and you have a handling beast.
I've said it before - Koni = ****, KYB = ***** - now which do you want in your face?
KYB's are actually okay shocks, just not as all out as the Konis, and the Koni's have a lifetime warranty.
Old Mar 28, 2007 | 07:00 PM
sanimalp's Avatar
$cat /dev/urandom
Default Re: (RSZero1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CRXBart &raquo;</TD></TR><TR><TD CLASS="quote">the best!</TD></TR></TABLE>
man i wish i could afford that whole setup right now..
and lifetime warranty is freakin sweet also..
Old Apr 16, 2007 | 02:33 PM
Agent_EM1's Avatar
Koni Yellow's are awesome, very stiff and made my 2000 Civic EX feel like my RSX, stiffness-wise. I paired mine with some Tanabe GF210 's which are an awesome spring in my opinion. YOu definitely get what you pay for but in this case, if you buy Koni's, you get a little more than you pay for because of its lifetime warranty. I've owned so many different cars and got to experiment with different rides. My Civic with Koni Yellows got stolen though so that sucks. Right now I have an Em1 on Tokico Blue's which are GREAT for the money. I personally don't liek KYB's and my second favorite shock next to the yellows are Tokico Illumina's. But even the Illumina's don't seem to get stiff enough to me for the track like the Koni's do.
Old Apr 16, 2007 | 04:51 PM
Pee Wee's Avatar
Default Re: (sanimalp)
450 shipped for Koni https://honda-tech.com/zerothread?id=1935513
Old Apr 16, 2007 | 07:32 PM
90JPRCRX's Avatar
Smells like Tuna
Default Re: (Pee Wee)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Pee Wee &raquo;</TD></TR><TR><TD CLASS="quote">450 shipped for Koni https://honda-tech.com/zerothread?id=1935513
he aint lyin
Old Apr 16, 2007 | 07:34 PM
gospeedgo1's Avatar
Default Re: (90JPRCRX)
KONI. do it right, do it once.
Old Apr 16, 2007 | 08:11 PM
.Manny.'s Avatar
Touching My Member
Default Re: (gospeedgo1)
KONI FTMFBBQORLYROFLWTFSTFUOMGW!!!
i just ordered my koni/gc package from nolimitmotorsport. cant wait to throw them on. i went with the 400f/500r rates.
Old Apr 16, 2007 | 09:34 PM
D16Z6racing's Avatar
&lt;--- Tokico only here. All my Honda's run/ran Tokico/H&R set ups.
Old Apr 16, 2007 | 09:45 PM
keenspeed94's Avatar
Default Re: Koni Yellow vs. KYB AGX (D16Z6racing)
for koni's just put them on awesome!!!!
