Built GSR Motor Set
As the title says, For sale is a Built NA GSR motor Set which includes and has the following done:
B18C1 Longblock:
CTR Pistons
Shot peened GSR Rods
ARP Mains
ARP Rod Bolts
ARP Head Studs
Factory Honda Headgasket
Power Enterprise Timing Belt (Blue)
Ported & Polished GSR Head
Buddy Club Valve Springs
Manley Titanium Retainers
Buddy Club Spec IV Cams
Buddy Club Gold Cam Gears
Type-R Valve Cover with Laser Cut Moon Cuts
Middle Timing cover with Laser Cut Moon Cuts
New GSR Oil pump
Longblock assembly was Cryoed
Hondata IMG
Skunk2 1st gen Intake Manifold
Spoon 70mm Type-R throttle Body
Type R Throttle Cable and Bracket
AEM Silver Fuel Rail
AEM Silver FPR
RC 310 Injectors
JDM Type R Header Jet Hot Coated
JDM Type R Upper and Lower Heatshields Jet Hot Coated
Type R Donut Gasket
Factory Motor Mounts
Engine Harness
Factory GSR Shift Linkage with Short shifter
GSR Distributor
Stock GSR Transmission
ACT HD Pressure plate
ACT Street Disc
ACT 8.8 lb Flywheel
[b]NO ECU WITH THIS SET-UP. If you want HONDATA or NEPTUNE, let me know.
Will sell the complete motor set with all the above for $4500 + shipping.
the motor only has around 13,000 miles on it. It was rebuilt a little over 2 years ago and hasn't been driven that much
Perfect motor for circuit
Will also come with Alternator, Power Steering Pump, and A/C compressor and drive belts
http://i166.photobucket.com/al...4.jpg
http://i166.photobucket.com/al...2.jpg
http://i166.photobucket.com/al...1.jpg
http://i166.photobucket.com/al...3.jpg
http://i166.photobucket.com/al...8.jpg
Modified by onesikdb8 at 2:08 PM 3/23/2007
Modified by onesikdb8 at 1:18 PM 4/6/2007
Modified by onesikdb8 at 3:59 PM 4/6/2007
B18C1 Longblock:
CTR Pistons
ARP Mains
ARP Rod Bolts
ARP Head Studs
New GSR Oil pump
Hondata IMG
AEM Silver FPR
RC 310 Injectors
Type R Donut Gasket
Engine Harness
GSR Distributor
ACT Street Disc
ACT 8.8 lb Flywheel
