Tranny problem please help!!
Old Mar 23, 2007 | 07:30 AM
onesikgsr's Avatar
Default Tranny problem please help!!
I have an 88 Lx 4 door with a 95 d16z6 motor. I had bolted up my original tranny from the d15 which worked perfectly, until one day it just wouldn't go into gear anymore. There was no signs of grinding or anything. So i thought it was the clutch. I tore down the tranny and found that a flywheel bolt and came loose and was hitting the clutch plate. So i figured that was the problem. I replaced the clutch and flywheel then put back my original tranny. The car still wouldn't go into gear. So i thought maybe the tranny was bad. So i bought a 88 si tranny on ebay. The guy told me it was good no grinds or leaks or anything. Just recently bolted it up and same problem. Im stuck and puzzled. I tried using a newer clutch cable and still wouldn't go into gear. Could it be possible that the tranny spline is misaligned with the clutch disc? Iono what else it could be, any help would be greatly appreciated. It will go into gear when the car is not running but when its running it won't go. Also there is a tranny leak by the shift linkage where the pin to the tranny is. I noticed that my tranny is leaking from there and my other trannys had a boot that went over it. If i put this little boot on will it help or prevent it from leaking?
Old Mar 26, 2007 | 07:07 PM
admess188's Avatar
Default Re: Tranny problem please help!! (onesikgsr)
Hey to answer the leaking question that will definilty help it and may stop it completely... I had that same problem...
Old Mar 27, 2007 | 07:21 AM
Gearspeed-Performance's Avatar
Default Re: Tranny problem please help!! (admess188)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by admess188 &raquo;</TD></TR><TR><TD CLASS="quote">Hey to answer the leaking question that will definilty help it and may stop it completely... I had that same problem...</TD></TR></TABLE>
Uhhh...that is just a dust boot . If it is leaking ...you could possibly have a bad shift shaft seal. Clean it up very good and check to see if it actually the seal and not a crack in the case.
7rrivera7
Jul 26, 2010 04:50 AM
slix_eg
May 10, 2007 03:39 PM
onesikgsr
Mar 23, 2007 09:43 AM
itr_234
Jun 14, 2002 07:49 AM
phatintegra
12
Mar 20, 2002 05:37 PM
