Gsr Cam Seal
Old Mar 23, 2007 | 07:12 AM
MRturbo's Avatar
Default Gsr Cam Seal
I just recieved my oem cam seals from honda and it looks totally different from the one on the diy on team-integra forum. i have part #12513-p72-003. is this the "new" design?
Old Mar 23, 2007 | 07:22 AM
Azn Kenny's Avatar
Hmmm I just ordered mine yesterday and got the same one as you did, maybe the one on TI is aftermarket, like STR or Golden Eagle.
Old Mar 23, 2007 | 09:19 AM
Sam92Teg's Avatar
Default Re: (Azn Kenny)
So that is the new design of the cam plug seal. I heard that they have the rubber o-ring like the aftermarket ones. These are for 96 and newer Integra models, but they should work on previous years also.
Old Mar 23, 2007 | 09:21 AM
99Geeezer's Avatar
Default Re: Gsr Cam Seal (MRturbo)
Ditch those and get an aluminum one. Not just for the looks but they do a better job in sealing. Although cheaper, the OE seals suck. either that or use a crap load of Honda-bond.
Old Mar 23, 2007 | 10:07 AM
Azn Kenny's Avatar
+1 on the Honda Bond, I'll be using a shitload.
Old Mar 23, 2007 | 10:28 AM
Sam92Teg's Avatar
Default Re: Gsr Cam Seal (99Geeezer)
Have you used the new design? If not, how do you know it sucks? I know the aftermarket ones work, but since Honda put an effort to improve their cam plug seal design, they might last much longer now. Maybe its worth $5 to try instead of $30 for aftermarket.
Old Mar 23, 2007 | 11:42 AM
reno96teg's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Azn Kenny &raquo;</TD></TR><TR><TD CLASS="quote">+1 on the Honda Bond, I'll be using a shitload.</TD></TR></TABLE>
please don't use a "shitload". that is such bogus advise. you should never overload on liquid gasket.
anyway, my OE cam seal never leaked ('96 RS). but i replaced it anyway when i did my timing belt job several months back, so i think it may have been the same as the seal pictured above. looks solid. i doubt it'll ever leak.
$5 &gt; $30
Old Mar 23, 2007 | 11:52 AM
MRturbo's Avatar
Default Re: (reno96teg)
i went with OEM cause its only $5.00 and it looks like it has been improved. sure is better thank forking out $30 for a damn cam seal with "STR" written on it. thanks for replies guys.
Old Mar 23, 2007 | 12:59 PM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Alright all you people hating on this part w/o ever using it need to stop talking about what you don't know.
My original cam seal was leaking when I did a tune-up on my car at around 125K miles or so. It was the original rubber cam plug. I replaced it with this newer-designed plug (pictured above), and now, over 4 years and nearly 125K more miles later, it still does not leak one bit.
SLOENUF
Mar 12, 2011 06:06 AM
nb0
Aug 10, 2007 03:12 PM
AznBlueBoy
Jul 11, 2005 08:24 PM
2k.civic.si
Jan 14, 2005 11:31 PM
MattyP
Dec 31, 2004 09:41 AM
