looking for oil cap breather kit
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SkankyEJ7 »</TD></TR><TR><TD CLASS="quote">dont you want baffling in front of a breather......ive seen setups like this use like a quart of oil in like 50 or 60 miles</TD></TR></TABLE><TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SkankyEJ7 »</TD></TR><TR><TD CLASS="quote">dont you want baffling in front of a breather......ive seen setups like this use like a quart of oil in like 50 or 60 miles</TD></TR></TABLE><TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SkankyEJ7 »</TD></TR><TR><TD CLASS="quote">dont you want baffling in front of a breather......ive seen setups like this use like a quart of oil in like 50 or 60 miles</TD></TR></TABLE>
thats what happened to mine . i didnt like the oil cap breather setup
i had to cut the webbing of my hood for it to fit
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PA MATT »</TD></TR><TR><TD CLASS="quote">interesting...they dont have any baffles in them at all? if they did, seems like it would be a good idea?</TD></TR></TABLE>
they don't... i made one myself before installing valve cover fittings.. its not the best idea to run a fitting that is not baffled. you'll end up having oil all over the place
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by extremevtecracing »</TD></TR><TR><TD CLASS="quote">http://etdracing.com/vibrantparts2.html</TD></TR></TABLE>
is the vibrant one baffled? so when people mod there valvecover for catchtank there using baffled fittings? what about the back of the block? do you have to use baffled fittings there too?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blinx9900 »</TD></TR><TR><TD CLASS="quote">
is the vibrant one baffled? so when people mod there valvecover for catchtank there using baffled fittings? what about the back of the block? do you have to use baffled fittings there too?</TD></TR></TABLE>
fittings are not baffled, valve cover is in certain points depending on what type of valve cover.. for me its efficient enough that i don't even need to run catchcans
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtec.dc2 »</TD></TR><TR><TD CLASS="quote">
fittings are not baffled, valve cover is in certain points depending on what type of valve cover.. for me its efficient enough that i don't even need to run catchcans</TD></TR></TABLE>
whats efficient enough? by baffle are you referring to the upper section of the valve cover on the long ends on both sides? i always wondered what those were for.
you must not be running a whole lot of boost. The more pressure you can relieve on the back of the pistons the better. You may want to consider adding ports in the valve cover and running a catch can.
