Uneven brake wear
Old Mar 22, 2007 | 08:48 PM
eric416's Avatar
Default Uneven brake wear
My front left brake started to squeak today and when i checked out the pads i noticed that the front left wore down almost twice as fast as the right one. The right caliper was replaced 4 months ago too. What could be the reason behind this?
Old Mar 22, 2007 | 08:59 PM
Hawkze_2.3's Avatar
Default Re: Uneven brake wear (eric416)
I guess if one caliper was harder to push than the other, then the easiest one to push would get the most braking force and wear down the pad more...
Old Mar 22, 2007 | 09:01 PM
john666's Avatar
i would think maybe your calipers are sticking. could try greasing it up a bit and seeing if that does anything.
Old Mar 22, 2007 | 09:37 PM
nonvteclude's Avatar
Default Re: Uneven brake wear (john666)
have you tried bleeding the brakes? mine did the same thing just needed to be blead
Old Mar 22, 2007 | 10:57 PM
eric416's Avatar
Default Re: Uneven brake wear (nonvteclude)
i'm gonna try to bleed them when i change them and see if it helps. Also, what part of the caliper should i grease?
Old Mar 22, 2007 | 11:40 PM
SnlpeR's Avatar
grease the floating pin
its where you bolt the caliper to
its the thing that freely moves in an out and has a boot over
one of mine was frozen stiff in the rear
had to take all the dried up grease out and regrease
Old Mar 23, 2007 | 09:15 AM
InvaderTrax's Avatar
Easiest way to check all of these is to reassemble it, press the pedal to get everything seated, then try to seperate the caliper from the rotor with a pry bar. If you can seperate them without extreme force, your caliper is good. Then, try to wiggle them back and forth. If they travel fairly easily, your slider pins are good. If it passes those two tests, the problem is with your lines or MC
swizz977
16
Mar 10, 2014 08:54 PM
jdmsir4dr
Suspension & Brakes
Mar 7, 2010 01:23 PM
1jdmek
Aug 24, 2007 09:13 AM
leekor12
Apr 19, 2007 07:05 PM
icedlee
May 6, 2005 03:54 AM
