aem wideband 6in1
Old Mar 22, 2007 | 06:42 PM
b18_racer805's Avatar
Default aem wideband 6in1
Probably not the right place but was wonder on the aem wideband will it work with out the plug ins to conect the sensor 2 the gauge cuz I baught a used one and the wires wire cut right bfore the plug can I sador them together so it work... thanks
Old Mar 25, 2007 | 12:25 AM
98_Coupe's Avatar
Default Re: aem wideband 6in1 (b18_racer805)
I imagine that the plug is cut off on the sensor side. People usually do that so the wire can be more easily routed through the firewall (because the plug is ginormous).
At any rate, the wires are color coded, so you shouldn't have a problem soldering them together.
Old Mar 25, 2007 | 05:53 PM
arc_55's Avatar
I would not solder them, i would use those sink tubing connectors instead, because if any oxygen is expeosed to the wiring the signal is inaccurate.
Old Mar 26, 2007 | 12:02 AM
98_Coupe's Avatar
Default Re: (arc_55)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by arc_55 &raquo;</TD></TR><TR><TD CLASS="quote"> if any oxygen is expeosed to the wiring the signal is inaccurate.</TD></TR></TABLE>
Lol, no way.
Cantcatchme
Engine Management and Tuning
Apr 4, 2012 03:48 PM
Boosteddb8
Jun 15, 2008 03:53 PM
jwbnavy
Dec 4, 2007 02:20 PM
s2kkid
Feb 18, 2005 10:14 AM
RAS Motorsports
Jul 10, 2003 11:52 AM
