throttle body
Old Mar 22, 2007 | 06:03 PM
slimjimdanny's Avatar
Default throttle body
i got a 94 gsr motor and i was wondering what would be a good size for the motor.. never bought one so i don't know.. there is this guy htat is selling his edelbrock one for 100 and its 70mm is that good or bad.. i got a guy to tune my ecu too.. and my manifold is a skunk2 pro series .. i got all the basic bolt ons .. and just wanted to know asap ... by tonight if possible.. thanks
Old Mar 22, 2007 | 06:12 PM
99Geeezer's Avatar
Default Re: throttle body (slimjimdanny)
I'm sure a lot of Honda-techers will say if your car is relatively stock to stay with the stock throttle body bore. I believe you won't need anything bigger unless you have bigger cams.
Old Mar 22, 2007 | 07:01 PM
all-mtr-teg's Avatar
Default Re: throttle body (99Geeezer)
70mm way to big for your setup. Go with a 65mm if you decide to get cams, if not, stick to the stock t.b.
Old Mar 22, 2007 | 08:54 PM
Default Re: throttle body (all-mtr-teg)
what's the size of the stock gsr throttle body? i wanna get something that helps...
Old Mar 22, 2007 | 09:08 PM
K2sInteg98's Avatar
yeah 70mm is wayyy to big. For you, i would get a 64mm just to match with your IM because the skunk2 IM opening is 64mm. Anything bigger, you better port match your IM so it flows freely, or else its gonna really hurt your flow.
Old Mar 23, 2007 | 12:17 AM
nokturnal_munkeeboy's Avatar
70mm and up are good for turbo or supercharge car, i would go with 66-68mm on the throttle body port to match intake mani with it.
Old Mar 23, 2007 | 08:12 AM
soundFX's Avatar
Default Re: throttle body (K2sInteg98)
bore ur tb to w.e IM you have or will get.
92_civic_lx
Sep 4, 2008 02:09 PM
GradyDC5
Jun 6, 2005 02:58 AM
BLK99VTECR
Jul 1, 2004 07:09 AM
B18C2_sedan
Dec 7, 2002 02:40 PM
