where did my VTEC go????APEXI SAYS ON...I SAY OFF!!!
Old Mar 22, 2007 | 05:49 PM
krytykalintentions's Avatar
Default where did my VTEC go????APEXI SAYS ON...I SAY OFF!!!
ok i got my apexi vafc set at 4500rpms for vtec 2 kick in....but i realized dat i could no longer hear or feel vtec kick in even tho the apexi was reading ON...i have no clue why it happend....new oil and i also cleaned the screen on the solenoid....any1 have any suggestions...BTW im running a b16a2 block...and 98 type r head!!!!thanks for any answers..
Old Mar 22, 2007 | 06:53 PM
gsr-2nr's Avatar
Default Re: where did my VTEC go????APEXI SAYS ON...I SAY OFF!!! (krytykalintentions)
check the operation of the soleniod itself,
Old Mar 22, 2007 | 06:58 PM
Default Re: where did my VTEC go????APEXI SAYS ON...I SAY OFF!!! (gsr-2nr)
how would i go bout doen dat???
Old Mar 22, 2007 | 07:05 PM
ImportHatch's Avatar
My car has da vtech on it. Whatcha wana do is take da sensa off, and spray sum hot sauce in it to give it da kick your looking fur. na mean?
Yager-
Old Mar 22, 2007 | 08:47 PM
DOHCgarage919's Avatar
From: Why To Steal My Car, NC, United States Of America
it can be ur apexi vafc my friend had a spoon vtec contoller vtec didnt work took it off vtec worked the spoon vtec con was burned ur vafc can be mest up and wont work just take it off and see
Old Mar 22, 2007 | 08:58 PM
-Championship-'s Avatar
76.169.175.137
Default Re: where did my VTEC go????APEXI SAYS ON...I SAY OFF!!! (ImportHatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ImportHatch &raquo;</TD></TR><TR><TD CLASS="quote">My car has da vtech on it. Whatcha wana do is take da sensa off, and spray sum hot sauce in it to give it da kick your looking fur. na mean?
Yager-</TD></TR></TABLE>
i was thinking da same ting, only i would set vtehc at 2,000 rpms and hold on to your socks
Old Mar 23, 2007 | 12:39 PM
gsr-2nr's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by krytykalintentions &raquo;</TD></TR><TR><TD CLASS="quote">how would i go bout doen dat???</TD></TR></TABLE>
get a voltmeter and a helms check continuity on it
Old Mar 24, 2007 | 01:19 PM
i finally jump da wire for da code.,, and its reading 22 (VTEC system malfunction) but like i said i have no CEL on... wat can i do???
Old Mar 24, 2007 | 01:21 PM
.Thomas's Avatar
use proper English.
ya no wut i mean?
Old Mar 24, 2007 | 02:28 PM
Default Re: where did my VTEC go????APEXI SAYS ON...I SAY OFF!!! (TanCar)
hey if u cant understand dat sh*t... F*ck off...u should b around A f*cking motor!!!!!!!!!
Old Mar 24, 2007 | 07:34 PM
JDMwhiteDC2's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by krytykalintentions &raquo;</TD></TR><TR><TD CLASS="quote">hey if u cant understand dat sh*t... F*ck off...u should b around A f*cking motor!!!!!!!!!</TD></TR></TABLE>
Your not going to get anyones help talking like that. You are just going to get flamed.
Old Mar 24, 2007 | 08:30 PM
401tuner's Avatar
and you exspect people to help you?
Old Mar 24, 2007 | 08:53 PM
TEAM JDM-P's Avatar
Default Re: where did my VTEC go????APEXI SAYS ON...I SAY OFF!!! (401tuner)
ok here it goes i dont know why apexi did this actually its backwards turn off vtec on the vtec controller, and it will actually turn it on in the ecu memory, same backwards turn it on in vtec controller and it turns off on car retarted huh ! thats what i said but thats how it is. Its the vafc right by apexi usa if it is then this is right.
Old Mar 25, 2007 | 04:14 AM
Civic92Turbo's Avatar
Have you tried tuning or a street tune? Adjust the vtec to engage at 1000 one the first run and then change it to 8000 on the second run,when you feel the smooths cross over, you should beable to find the best cross over.... also 4500 seems to low to engage into vtec, I have mine set at 5500 on uberdata with ctr cams where I again an extra 4hp when vtec cross over
Old Mar 25, 2007 | 05:43 AM
Default Re: where did my VTEC go????APEXI SAYS ON...I SAY OFF!!! (Civic92Turbo)
thanx for the info...sorry for the burst!!
dx2sicrx
Engine Management and Tuning
May 19, 2008 10:21 AM
bja2704
Oct 22, 2005 01:01 PM
bchomka
Oct 31, 2004 08:48 AM
cookci
Apr 6, 2004 01:24 AM
B18Redline
May 27, 2003 10:07 AM
