What Parts for MPFI Swap?
Old May 24, 2002 | 09:17 AM
OldSchoolHatch's Avatar
Default What Parts for MPFI Swap?
Hey,
I know there's many topics about this on here already, but I still need help. I'm getting everything I need off an Si from a member on these boards for the MPFI swap. I found out everything I needed and here's what I told him:
"I would need the complete intake with the intake tube and throttle body, injector resistor box and wiring harness, ecu, distributor, and coolant hose. And if you have them, plugs from an engine harness like injector plugs, injector resistor box plug, and distributor plug."
I don't think you have to have all those plugs, it just helps in the process right? Here's what he sent me:
"When you mean plug's, do you mean the harness plugs? If so that the engine harness then. Ok lets get it stright = intake with tube, throttle body, ECU, distributor, coolant hose( upper and lower)......Injector??? what do u mean just the injector's and the resistor box is there anyway you can get that. The resistor box is sold...sorry."
Please set me straight if you know about this.
Old May 24, 2002 | 09:19 AM
SuperCivic's Avatar
Default Re: What Parts for MPFI Swap? (OldSchoolHatch)
i'm pretty durn sure you need the injector resistor box.
crex23
May 20, 2005 02:47 AM
dingusjt
Oct 9, 2003 06:02 AM
TDRacing
Jul 29, 2002 07:37 PM
vtecrx
Jul 22, 2002 02:16 PM
