Need help engine performance..
Hey guys i want to build a fast little LS, i have a 97 Integra LS so far only I/H/E system. I heard the P30 pistions are the best for my car is this right and these are the right ones right?
http://cgi.ebay.com/ebaymotors...wItem
Do Cam gears even do anything? I am also getting a Camshaft for my car also and need brand suggestings or Model. (Need to run premium after this right?) I want Stage 2 will it pass Cali Smog????
Any other Mods you guys suggest that i do while i am inside or around engine? I think i need to upgrade my fuel pump?
Thanks, Brian
Modified by BKKloppenborg at 6:43 PM 3/22/2007
Thanks, Brian
i would suggest getting camshaftS, just one camshaft wont do much good.....
j/k.
http://www.nonvtec.com has some good info on non vtec builds, as does the N/A section here.
j/k.
I'm sure someone will disagree with me but I'd be cautious about what cams you use. It may not pass the sniffer at the smog station. Even LS/VTEC conversion may not pass visual unless approved with a bar label from a referee but i could be wrong there. If you go with LS/VTEC stay with Civic Type R cams. you may have a better chance with those cams. Some one else may have some experience with a smog test with this set up.
If you did a GSR swap, you'll be okay with smog since that was an optional engine for that vehicle. Just keep all the emission controls intact. LS/VTEC might be considered modified by a seasoned inspector thus causing you to fail.
Modified by 99Geeezer at 10:50 AM 3/23/2007
Check this out if you are interested in doing the ls/vtec build
https://honda-tech.com/zerothread/1923227
Is Vtec worth the price? Around 1K for a extra 10hp about? would the accleration be faster?
Ot should i just stay with Dual overhead LS B18b and get come good cameshafts, pistions, camgears, and maybe Turbo..
10 hp? how;d you come up with that?
you;d be looking at about 30 crank... wanna make it fast? 3k for a turbo after that, total 4 for about 250 crank and you've got a quick little car.
the way i see it, you at least get the vtech for a higher redline... then the turbo for a bunch more power... although personally, im thinking sc for that torque increase. whats 250 hp if you can't climb a hill?
i have some crower stage 1 cams for your LS. I built my LS before using these, blox intake mani, and itr tranny with 4.7 fd. Man, my car pulled. I have em for sale if u want. PM me if u want these.
30 Hp really is it worth it then Vtec? If so that is my next product...
O that sounds good LOL
Vtec, Camshafts, P30 pistions, I/H/E, camgears, then a Greddy Turbo.. mmmmm
wow expensive but worth it lol Sleeper..
1K vtec, Camshafts, Pistions, Camgears 700 dollars Turbo 2K Other parts needed 1K
4.5K LOL Is is going to be a Product over next 3 years
DougieStyle
Dec 7, 2005 10:59 AM
4genaccordfreak
10
Jan 10, 2004 10:30 PM
XEF-9X
Jul 24, 2002 02:13 PM
