Something different: P/S rack to manual steering rack bushing
this is going into a DA integra that is being prepared for touring class racing... they were swapping out the p/s rack for a manual one out of a crx and the es bushing didn't fit the smaller diameter manual rack so i made up a split bushing out of delrin to fill the gap. i would have made a whole new bushing out of delrin that could be bolted together but local suppliers wanted $25 for a 4" piece of 2.5" round delrin! i already had the 2" so i made the sleeve instead. if it doesn't work out well i'll just make a whole new one out of aluminum.
new rack:
close up of the delrin sleeve with the es poly that fits the p/s rack:
sleeve installed, note it fits snug enough to hold itself on without falling off:
now the es poly bushing overtop:
ready to shred corners!
new rack:
FYI. I had similar problems with putting an EG manual rack in place of my DC power rack. I thought of doing something similar to what you did but I didn't like the idea of the rack being crooked the thickness of the delrin. (although I am sure this won't make much of a difference) So I opted to just use an EG manual rack subframe. It took some time to hunt one down because everyone I dealt with didn't know there was a difference in subframes. BTW your work looks good. What tools did you use to make it?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CVC9216 »</TD></TR><TR><TD CLASS="quote">is there any danger of the sleeves wiggling out over time? maybe there should be a shoulder on the sleeves to hold them in place?</TD></TR></TABLE>
that was my concern but i guess it sits inside a pocket or something that will help prevent that and then gets a strap across the other half to hold it all together? i'll have to get some pics of it installed.
honda93
Aug 26, 2002 02:57 PM
