Prelude, H22A, with Idle problems. Please help!
Old Mar 22, 2007 | 04:51 PM
JBirch_97Prelude's Avatar
Default Prelude, H22A, with Idle problems. Please help!
I just had a blown H22A4 swapped out for a H22A. My tech was able to keep the car OBD2. The only problem is after driving for a while the car stops idling. Someone in the Prelude forum said that it could be the map sensor, so I ordered one today but now he is saying that it did not fix the problem. The intake system has alot of build up so I am going to clean it up the EGR Valve, throttle body, and anywhere that may need to be cleaned with carb cleaner and replace the distributor and rotor. Plugs and wires were replaced yesterday and it continued to have the problem.
Old Mar 23, 2007 | 10:53 PM
Tacoma Luda's Avatar
Default Re: Prelude, H22A, with Idle problems. Please help! (JBirch_97Prelude)
Aye i had the same problem putting my h22 swap in. I did all that and still did it. It was my throttle cable. It was to tight and it was causing my throttle to stick. Try that and see if that works
Old Mar 24, 2007 | 07:27 AM
Default Re: Prelude, H22A, with Idle problems. Please help! (Tacoma Luda)
Thanks alot! I will let you know if it helped!
Old Mar 24, 2007 | 07:51 AM
preylude's Avatar
If it revs up and down like there is a loop problem, mine did that and we had to replace the fast idle control valve. Honda said it never breaks, so we had to remove it from another h22 motor. Another possibility.
Old Mar 24, 2007 | 08:55 AM
Default Re: Prelude, H22A, with Idle problems. Please help! (preylude)
No, it is just not Idling! Once it get ups to operating temperature.
Modified by JBirch_97Prelude at 3:26 PM 3/24/2007
avargas28
May 27, 2009 12:22 PM
JBirch_97Prelude
Mar 22, 2007 05:27 PM
