changing expansion valve
Old Mar 22, 2007 | 04:44 PM
akkord94's Avatar
Default changing expansion valve
well my uncle told me mine is clogged. wondering how hard of a job it is? anyone got step? please help
Old Mar 22, 2007 | 04:45 PM
akkord94's Avatar
Default Re: changing expansion valve (akkord94)
oh yeah i have a 97 GSR
Old Mar 22, 2007 | 05:17 PM
Sam92Teg's Avatar
For starters, you have to drain the system, drop the evaporator housing, swap the expansion valve, pull a vacuum on the system, and refill the system. The drier is usually swapped when you open the system like this. This is slightly over-simplified, but should give you an idea of what is involved.
Old Mar 22, 2007 | 05:39 PM
akkord94's Avatar
Default Re: changing expansion valve (Sam92Teg)
where is the evaporator housing?
Old Mar 22, 2007 | 05:41 PM
schardbody's Avatar
behind the glovebox, the 2 lines that run into the firewall under the hood lead into the evaporator core (housing), this should give you a general i dea of where its at.
Old Mar 23, 2007 | 03:45 PM
akkord94's Avatar
Default Re: (schardbody)
does anyone know where a step by step for this would be?
Old Mar 24, 2007 | 07:34 AM
schardbody's Avatar
its very self explanitory once you get into it.
Old Mar 24, 2007 | 07:48 AM
Sam92Teg's Avatar
$15 Haynes manual, I buy one for every car that I own and it pays for itself the first day of ownership.
maxboost10
13
Jul 26, 2022 02:22 AM
bns2000
Jan 25, 2007 12:25 PM
slickrc
Apr 26, 2006 06:59 PM
turrismaldon
Jun 18, 2004 02:25 PM
